RVN 355
- Feb 25, 2005
- 2,611
- 19
- 0
- Age
- 38
- Location
- WEST SUBS
- 91 VN SS 355
2005 Pictures of VN SS when purchased with Original Number Plate - WXY 476
2006 Pictures Before 355 Stroker Rebuild with old Custom Number Plate - SUBDUE
355 STROKER 2007
SUSPENSION / DRIVE TRAIN
INTERIOR
PAINT + ACCESSORIES
- R SLOGAN PLATE : RVN 355
- 1991 VN SS 355 Stroker
- Power Pack Optioned
- Level 2 dash with tacho
- FE2 suspension
- Genuine SS bodykit
- Long Range Fuel Tank (80L)
- Paint code: (Alpine White)
- Side pinstriping with SS decals, pinstripe on front & rear bumpers
- ‘SS’ and ‘Holden’ Decals on rear spoiler
- Sports seats (series 2), grey with red piping and inserts
- 19" RJR Torque 245 X 35 Chrome Wheels with 5mm universal spacers
- Maxxis MA Z1 Directional Tyres
- 10mm Red Walls - White Walls S.A
- Bendix Advance Brake Pads, PBR Rotors
- Tinted Windows 10 %
- Pro Alarm System
- 1.1KG (Kidde) Fire Extingusher mounted in the Boot
- Replaced New Tension Bearings
- Replaced New Regulator on Alternator
- Replaced Washer Bottle Motor 29/2/08 SVM S.A
- Calcium King 13 Plate 530 CCA Battery (Made by Delco)
- Replaced Thermostat 130degree 21/3/08
- KYB Excel G Front strut & Rear Shockers (short Stroke)
- Nolathane Strut Tops Adjustable
- Nolthane Strut Brace Adjustable
- New Stub Assembly
- New Engine Mounts
- Nolathane Rear Lower Control Arm Bushes
- Nolathane Front Lower Inner Control Arm Bushes
- Nolathane ADJ Panhard Rod + Bushes
- Nolathane FrontHeavy Duty Sway Bar Link Pin Kit
- Nolathane Strut Bar too Chasis Bushes Front
- New Uni Joints
- New Wheel Bearings
- New Tail Shaft
- GMH Z bar
- VL TURBO LSD 3.4.5 DIFF Gears
INTERIOR
- Issota (Made In Italy) Evoluzion Leather Steering Wheel (ADR APPROVED)
- Blue LED's in Interior Light
- VS Boot Carpet
- VS Commodore Sun Visors
- VR Caprice Cig Lighter
- Grey Velour Roof Lining
- Custom Vs Door Pods with VN SS Material Used.
- VR Caprice Centre Consol (LEATHER)
- RVN 355 Stainless Steel Din Cover Polished
- Custom Embroadary on Centre Consol Lid - RVN 355
- Charcoal Leather Red Piping Hand Brake
- Replaced Windscreen - United Windscreens 2006
- Autometer Guage Pod Mounted Passager Side
- Vs Caprice Style Chrome Interior Door Handles
PAINT + ACCESSORIES
- Alpine White,VZ SS V8 Badge Fender, VE SS Badge's on Rear Doors Above Side Skirt
- Re Sprayed Engine Bay 2pac Original Alpine White
- Re Sprayed Rear Bumper,Bonnet Hingers Alpine White
- Re Sprayed VP 5000 Letter Box Grill Alpine White
- Re Sprayed Window Mould 2 Pack Black Enamel
- Cut & Polished Paint Work
- Detailed Seats Jan 08
- Original VN SS Pin Decals Kit Replaced
- Colour Coded Re Sprayed Alpine White Electric Mirrors
- Phillips H4 Blue Vision 4000K Headlights Halogen Globes + Parkers
- Engine & Various Engine Components Painted Alumininium "Silver POR 15"
- Painted Alumininium "Silver POR 15" Engine Mounts
- Resprayed Bonnet & detailed Inside 2007 - SVM
- Aluminium Tig Welded (High Pressure) Expansion Over Flow Bottle - Bremen Welding & SVM
- Polished Aluminium Tig Welded Washer Bottle - Bremen Welding & SVM 29/2/08
- Polished Aluminium Tig Welded Fuse Cover with SS Engraving.
- RVN 355 Engraved Billet Aluminum Master Cylinder Cover
- RVN 355 Engraved Billet Aluminum Oil Cap
- RVN 355 Engraved Billet Aluminum Power Steering Cap
- SS Engraved Billet Aluminum Radiator Cap
- SS Engraved Billet Aluminum Strut Caps
- SS Engraved Billet Aluminum Washer Bottle Cap
- Custom Made Stainless Steel Battery Cover
- New Bonnet Cable 21/10/07
- RJR Chrome Wheel Caps
- 16cm Aeropro Stero Din Dize Blue 12V Neon Behind RVN 355 Custom Din Cover.
- New VN SS Foglights + Lenses
- 8-10mm Plastic Chromed Ignition Lead Holders - Sydney Speed Shop
- Billet Trans and Engine Dip Sticks
STEREO
HEADS
- Pioneer DEH-P1Y MP3 60Wx4
- Pioneer 12" Sub + 2005 Pioneer Sub Cover
- Pioneer 220w Bullet Splitz
- Pioneer 5way 400w 6x9's in Rear Fiberglass Pods
- Weconic 4ch Amp 800w 75W X 4 RMS
- Sony 222w 2 Chanel Amp.
HEADS
- Machine & Clean Heads
- Faced Valves
- 3 Angle Grind
- Profile Machine Valve Seats
- K Liners
- GMH head Kit
- 2.02" Exhaust Inlet, 1.6" exhaust outlet
- Flow benced 500+ hp
EXHAUST
- Pacemaker 5002 44mm Primary Headers Including HP Coating - AAA Exhausts S.A
- Pacemaker 3" 5002 Exhaust Y piece (Brings headers into single 3" System)
- 3" X Force Matt Black Mandrel bent Exhaust System
- 3" Magnaflow High Flow Catalytic Convertor
- 3" X Force High Flow Muffler
- 3" Stainless Dump Pipe
ENGINE & COMPONENTS
- Torque Plate Honed,Acid Dipped, Crank Tested,Decked & Blue Printed C.O.M.E "Racing" Nodular Recipricating 355ci Billet Stroker
- King Bearings & ARP Rod Bolts
- Speed Pro Gasket Set
- Crow Cams Pushrods
- Speed Pro Flat Top Forged Pistons
- 5 .7" I Beam C.O.M.E Conrods- Floating Conrods non press fit
- l34 Stainless one piece Valves
- Crane 284 Camshaft,Crane Anti Pump Lifters,Crane Valve Springs,Crane Retainers,Crane Valve Locks
- MSD Ignition P2225 - External Performance Fuel Pump Rated @ 500hp
- Holden VS V8 CAI,Holden VS V8 High Flow Air Box Top & Bottom, Rush High Performance Air Filter.
- Yella Terra Platinum 1.6.5 Roller Rockers
- JP Performance Oil Pump
- Injectors Chemically,Flow Benched, Cleaned and Tested with new O Rings
- Kilkenny Casting Timing Cover
- Rollmaster Double Row Timing Chain
- Powerbond Street Series Harmonic Balancer
- GMB Water Pump
- Haltech E6GMX Engine Managment System - Dyno Tuned on V power 98 Shell 172.6 Rwkw - Blackwood Dyno March 2008
- PRB Master Cylinder
- NGK Spark Plugs
- Top Gun 8.8mm Red Performance Leads
- New GMH Clutch Fan + Shroud
- GMH Belt
- Cleaned IAC Valve,Throttle Body & replaced TPS.
1st service of Rebuild @ 192,500km 6th December 2007 - Paul Pavlou Motors,Valvoline 10w 40 Dura Blend,Wynns Coolant.
TRANSMISSION
Pro rebuilt TH 700 R4 Automatic lock up hydraulic controlled Transmission September / October 2007 - Steve@ Paul Pavlou Motors
METAL POLISHING / PAINTED ENGINE PARTS
- CORVETTE SERVO PISTON
- OVERSIZED HIGH PERFORMANS WIDE BAND
- RAYBESTOS MODULE
- FAIRBANKS STAGE 3 RACE APPLICATION T 700 4 SHIFT KIT
- NEW CLUTCHES
- STEEL T700 R4 - 4L60 E (.110)
- NEW TRANSMISSION PAN
- NEW TERRINGTON BEARINGS
- NEW FULL GASKET SET
- NEW VALVE BODY PLATE
- T700 OVERHAUL KIT
- MACHINED WASHER TRANS DRUM PUMP
- NEW TRANS FILTER
- NEW SEALS
- 2500 STALL CONVERTOR
- 0.55 " BOOST VALVE
- Polished 5000 Injection Rocker Covers
- Polished VN 5000 Injection Engine Covers
- Polished Receiver Dryer Air Conditoner
- Polished Nolathane Strut Brace
- Polished Custom Fuse Cover + Relay Cover
- Polished 5000 Injection GMH Manifold
- Ported & Polished V8 Throttle Body Inside + Outside
- Polished PBR Master Cylinder
- Polished Water Pump
- Polished Timing Cover
- Polished Trans Pipes
- Polished GMH Ignition Module & Painted Red Hot Enamel Sourrond of Heat Sink.
- Polished Alternator + Painting "GMH VZ Red Hot 2 Pac Enamel"
- Chromed Alternator Bracket
- Chromed Power Steering Pump & Bracket
- Polished Thermostat Housing
- Polished Dip Stick
- Polished VN Fuel Rails
- Polished Master Cylinder & Brackets
- Polished Bolts / New Screws or Bolts For All Parts
- Polished A/Con Pipe From Compressor To Receiver Dryer
- New Strut Top Bolts
- chromed alternator + pulley,crank and power steering pulley
- New Vs Fender Bolts Polished
- Headlight Clips Polished
- Chromed VN SS Bonnet Hingers
- Stainless Steel Hand Polished Gas Struts to suit vn ss
- Chrome Bonnet Safety Catch Brand New
- Chrome Bonnet Lock Pin & Spring
- Painted Black Throttle Cable
- Polished All Billet CNC Machined Custom Caps
- Polished 4x Door Catches & Screws
- Polished Boot Catch & Screws
- Polished Aluminium Washer Bottle,Radiator Overflow,Fuse Covers
MODS INTO 2008
ENGINE BUILD COMPLETED PICS 2007
Special Thanks To:
- Custom Oil Filter cover
- Metal Chrome Outer Door Handles - Done but not installed as yet.
- Hide Engine Bay Wiring
- Chrome Strut Tower Bolts - Ordered
- Autometer ultra lite Oil Pressure Guage
Special Thanks To:
- My Girlfriend,family and my Mates-Scott,Tim,Frank,Stephen
- All The Boys in the Just Commodores S.A Scene
- S & B Auto Electrical
- Sprints Performance Kilkenny - Marcus
- Exeter Crash
- North East All Transport Upholstory
- All Torqure Convertors
- S.V.M Metal Polishing (KARL)
- Tisonics
- Motoquipe Westlakes
- Jeff the plastic chromer
- S.A White Walls
- Mc Laren Engineering
- AAA Exhaust
- Blackwood Dyno Tune
- Woodville Park Auto Repairs
- West Croydon Auto Repairs
- Growly Custom Machining
- VNSS CLUB
