hard 2 start
burnz
dah dut dut da dah
springfield
VFII SS ute M6
start easy when cold easy when hot wont start when warm
problem
61
VR, VL Cal Turbo, VL GRPA
Have a look at the thread I posted on the 2/9/05 titled The bugger won't start properly. I looked and replaced a lot of items including the crank angle sensor and eventually found the problem to be the fuel pressure regulator.
Pull the vacuum line off the fuel pressure regulator which is the small stainless steel cylinder attached to the rear of the fuel rail on the drivers side of the engine. The vacuum operates a diaphragm and varies the fuel pressure in the fuel rail. If there is any fuel in the vacuum line the diaphragm has ruptured and the fuel can run straight into the inlet manifold and flood the engine and the bugger won't start properly.
burnz
dah dut dut da dah
springfield
VFII SS ute M6
i would got back earlyer been away ill check that hope it's it. thanks
Offensive picture removed.....Rat.
burnz
dah dut dut da dah
springfield
VFII SS ute M6
spot on problem solved thanks
