HaloNick
Holden Fan, AUS and US
- Apr 9, 2007
- 14
- 0
- 0
- Age
- 40
- Location
- Mona Vale, NSW
- VR Acclaim A4
Well we got our Commodore on April 13th. We went to do some suspension stuff (springs, struts, shocks) on Saturday and noticed the wheels have lock nuts. No biggie. Had to find the key first of all, and found it with the spare (full-size oddly enough). So I look at the key and two of the four teeth are gone. Hopefully they will still come out with half of the teeth in the key. First try on the driver's side front wheel...slips off. This happens a couple of other times, and then we find out that another tooth on the key is now gone :bang: . So now the key is useless because it has also rounded out the little holes in the lock nut. So since we did almost all of the work on our cars in the States, we decided to give this a go. The lock nut basically disintegrated while we tried to chisel it round the bolt.
We took it to a place today, recommended by Jax Tires, and a few hours later they call and say they can't get them to move at all. I go to look at it and they had the same problem we had in that they tried to chisel the nut around the bolt and it disintegrated. So they recommend another place (a real tire place this time). We go there and they say that they should be able to get them off but will need to leave it for the day. Hopefully they can get them off without having to destroy the wheels. If not, then we will be getting some more wheels. :thumbsup: and also :bang: at the same time.
