0-100km/h times
Bz Kn33z
Mildura
Black VN V6 Turbo
The time it takes to go from 0 to the end of first gear into 2nd, how like it takes the shift would be around 60-65kph, my old white vn i clocked at 3sec
Didnt know there was a 2nd page lol.
Bz Kn33z
Mildura
Black VN V6 Turbo
That wasnt at the end of 1st to 2nd shift that was just to 65kph, and auto was stuffed so took ages to get into 2nd
Troy5L
building a lemon
Mornington peninsula
Gu patrol td42
my old vr just had a chip, 2.5"exhaust and CAI and that did mid 7's
greenfoam
102
VP Executive R-spec
Clearly isn't my car since it's got too much grunt for a stocker but worth a look :) (for about 10 minutes)
Times up
crazybiker
Sydney NSW
VR Commodore V6
doesnt anyone shift manually in n auto.. or in a manual at which speed do you all shift to 2nd.. i change from 1 to 2 about at 65-70
Dont use the speedo, but I usually change at about 5200RPM.
Which, from calculating it, is around 62km/h.
Eliminator
Maranello red Vn V8 Calais
hopefully i should get similar results with diff gear swap, corvette servo, cai & a vr based tune off you instead of this vn based one... not expecting it to be the same cause yours is lighter but if i can do a 6 second flat 0-100km/h with ease then id be happy :)
crazybiker
Sydney NSW
VR Commodore V6
I'm planning on changing mine over to a 3.45 LSD eventually.
3.7 seems a bit too much for my liking.
Kenneth91
33
99 vt calais
How to fix no take off speed my 99 vt calais had power taking off but now it doesn't is there anyway to get power back to it
