01 VU Ute Surging/Splattering HELP
Uncledavo
2001 Vu Ute
Hey all,
I have owed my Ute for 3 years now and in the past 4 months it has started coughing/splattering/surging. It seems to happen mostly between low revs at about 3000rpm. after the first couple weeks i started changing things here and there to fix the problem;
Items changed;
-oil
-oil filter
-plugs
-leads
-fuel filter
-air filter
-coil packs
I have been trying to avoid putting my money into more expensive items due to im not 100% sure which one of them the problem could be coming from eg; fuel pump/injectors.
The ute is a V6 manual, and has done 250,000kms. would love some other peoples opinion on what they think it is before i start forking out more money, cheers UncleDavo....
Uncledavo
2001 Vu Ute
Actually i haven't, ill give it a crack now and get back to you... cheers
SavVYute
VY S V6 Ute Series II 2004
Loose or leaking rubber hose in engine bay somewhere?
Check the one that connects under the throttle body.
vx_commodore
35
Sunshine Coast QLD
VX Commodore 'S
I'd be thinking along the line' of fuel pump, These can be sign's of a bad fuel pump.
Have you tried some GQ injector cleaner?
Could even look at getting the fuel system pressure checked, Just to rule it out.
smokem
47
vx ss 5.7
oxygen sensor on the pipes!!!
id be willing to do a cash bet with ya on it!!
