jem001
- Jan 9, 2009
- 3
- 0
- 0
- wh statesman v6
Very intermittently my 2001 wh v6 will not idle at all, runs fine so long as you keep your foot rested on the accelerator. Also intermittently misses but not at the same time and more frequently than the idle problem. Also intermittently struggles to start, sounds like it has a flat battery but lights work fine and battery has power so far has always started.
Have replaced fuel pump and filter, plugs, leads, coil packs and dfi, cleaned throttle body, replaced key, replaced battery, checked alternator output.
Also can hear a very slight rattle in the engine (possibly timing chain) when accelerating up hill, is fine under full acceleration on level gound.
Has me beat, any ideas would be appreciated.
