D
death-from-above
Guest
I did a fault code check last night on my VS and it came back with this:
12 No RPM Signal (OK stationary engine)
13 No RH Oxygen Sensor Signal
45 RH Exhaust Rich Indication
57* Injector Voltage Monitor Fault
63 No LH Oxygen Sensor Signal
65 LH Exhaust Rich Indication
76* LH & RH Short Term Fuel Trims Differ
78* LH & RH Long Term Fuel Trims Differ
The main thing that concerns me is the 02 Sensors, I have the service history of the car and both 02 sensors where replaced in July 2002. At $91.50 a piece I dont intend to rush out and buy two new sensors every so often. Any ideas as to what could be causing the problem? Im going to reset and do the relearn procedure just to make sure that if it was done after the installiation of the 02 sensors, so Im not picking up an old fault.
