044 fuel pump curcuit
NOT 38
brisbane
vn commodore
hey guys just a quick question.
im setting up a 044 and surge tank, its fed by a stock intank pump, can i run the 044 off the same circuit as the intank pump, or do i need to run a seperate cicuit??
if so what is required.
Commydoor
born in the FB era
Beresfield, NSW.
Vr Ss Blown
i spliced mine into the stock pump wiring with a fusible link on the power lead going to the 044...dont reckon it needs the fusible link but fitted it anyway...and i have a larger spare fuse in the glovebox for the fusebox in case the current draw is too much and blows it...so far so good havnt suffered any problems...
Claudy
French Com
Perth, Two Rocks
Manual Gen3 VT SS + V6 VT manual turbo
Posted on here before but musnt have worked. I believe u need to run a bigger wire than standard and a fuse and relay because the 044 draws more current(amps) than the standard fuel pump.
Claudy
French Com
Perth, Two Rocks
Oh there ya go should be alright then! But maybe wouldn't hurt to run it's own wire if ya can or can be bothered haha
colgf
s/charged v6 HR Holden, s/charged v6 EH Holden,
044's draw about 20 amps buddy. I would run a separate relay triggered by the in tank pump , with a supply wire straight off the +ve battery terminal & an inline fuse just after the battery .
NOT 38
brisbane
vn commodore
would any one be able to do up a diagram for me at all ?
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
all i do is run another power wire to the rear same size as an amp wiring kit 30-35 amp proof then i use the old wire to the tank to trigger a relay for each pump
