06 VE Wont Start after putting multimeter on ignition wiring
Discussion in 'VE Holden Commodore (2006 - 2013)' started by brandon_hi, Nov 11, 2012.
  1. brandon_hi
    brandon_hi New Member
    ipswich
    VE V 2007 3.6L
    After testing ignition wires with a multimeter to find the ignition start wire, the car is no go. Didnt disconnect anything or cut any wires but now its like the immobilizer is on and cannot reset it. Can open and lock car, dash all lights up, etc. but no starter motor cranking. Have tried several things in the forums like disconnect battery and fuses and waited a while, but now getting error messages like ABS Fault, also says Contact Dealer, also says LOW FUEL and its not low. Stability Control faults as well. And the car still will not start. Is there some way to reset the ECU or the immobilizer or is it a tow truck to the dealer?? Any help you can give would be great :D
  2. ephect
    ephect Donating Member
    VS Acclaim V6
    When U where poking around did U happen to short 2 wires with the one probe? Almost seams like that's what happened.
  3. brandon_hi
    ipswich
    VE V 2007 3.6L
    possibly not sure though
  4. Benboy
    Benboy Well-Known Member
    Hill River, SA
    2007 SVZ Wagon
    Disconnect battery for 5 - 10 minutes and hope it resets the 'system'.
  5. brandon_hi
    ipswich
    VE V 2007 3.6L
    Yeah I tried that but no luck :(
  6. salute the ute
    salute the ute DRIVING IS A PASSION
    Rowville
    VE Ute Series II Perfect Blue
    Check all the fuses in the passenger side foot well. When I was playing around with some interior lights that are hooked up to the ignition wiring I blew a fuse and the car would not start. Specifically mine was a 2 amp mini fuse which is hard to come by but jay car had them their.
  7. brandon_hi
    ipswich
    VE V 2007 3.6L
    My fuses are in the engine bay and I looked at the fuses and they seemed fine so I don't think that's it I'm thinking like the immobilizer has been activated or something
  8. salute the ute
    Rowville
    There are some in the engine bay and should also be some in the passenger side foot well on the door side. There is a little panel that you pull towards the back of the car.
  9. huthy14
    huthy14 New Member
    Canberra Act
    ve ss
    And in the boot of sedan I know
  10. salute the ute
    Rowville
    could try that but i'm sure anything to do with the ignition will be found in the fuse box in the foot well
  11. brandon_hi
    ipswich
    VE V 2007 3.6L
    Cheers mate that did the trick does any one know how to get rid of check engine error
  12. salute the ute
    Rowville
    So your car starts now ?
    Try disconnecting the battery for 10-15 minutes
  13. NVE_069
    NVE_069 New Member
    Wh Statesman LS1
    What mobi phone you got? If android get urself a OBDII Bluetooth dongle off eBay. Download the app and you can check and reset codes from your phone. Also helps when there is an Error. Save u some paying others too tell you what's going on.
  14. brandon_hi
    ipswich
    VE V 2007 3.6L
    Aw mad cheers, thanks heaps for the help guys really appreciate it :)
  15. salute the ute
    Rowville
    Though for something like this just disconnect the battery, I would recommend WIFI instead of bluetooth much faster and works better IMO
  16. brandon_hi
    ipswich
    VE V 2007 3.6L
    Yeah man thanks for your help
  17. salute the ute
    Rowville
    Thats okay mate, I know its a scary thing when the cars not starting, yet its a 99 cent fix :)
  18. brandon_hi
    ipswich
    VE V 2007 3.6L
    Haha yeah thank god I was worried i had to take it to a dealer and get charged a few hundred
  19. salute the ute
    Rowville
    Yeah that was my fear too, Dad cracked it when it wouldn't start and I had no idea what the problem was.
  20. brandon_hi
    ipswich
    VE V 2007 3.6L
    Well my dad didn't care cause he didn't pay for it so he was laughing along with my mates
