07 Holden barina timing belt
Knightsy82
39
Holden barina
Hi. I’ve got a problem with the timing belt feeding off as turning motor over by hand. I bout a motor and done the timing belt water pump ect once all back together turned over to check and belt keeps feeding off after 4 revolutions of cams. Never had this problem before not sure why any help is appreciated cheers
mechanic
Australia
Commodore
Did the engine run before you started the repairs?
Were the replacement parts identical to the original?
Are all pulleys aligned? Use a large straight edge to check.
Is the crank pulled washer on when you crank? The crank pulley itself may stop the belt coming off.
Is the belt over tensioned?
