1.91 rockers question
twoshay
37
VT commodore
Can these rockers be fitted on the stock rails? vt ecotec?
MACE
Hi twoshat,
Thanks for your enquiry.
"Can these rockers be fitted on the stock rails? vt ecotec?"
You can't unfortunately, otherwise, it will cause engine damage.
If you have any more questions please don't hesitate to ask.
Kindest Regards,
Steve
EYY
VS Statesman
You'll be filing for quite a while. Can use a die grinder to give extra clearance for the pushrods though if you're careful.
MACE
You certainly can, or you can even use an angle grinder if you're careful.
With ours, we CNC the slots longer to facilitate the change in pushrod position.
Best Regards,
Steve
commodore665
expat Saffa
51
New Zealand via Cape Town
2005 SV6 & Alfa Romeo 156 V6
Hey hey ,
I'm a little curious about the throttle controller that is available on your website , I already have a Mace CAI and the 25mm insulators on my SV6 , so I'm guessing extra gains would be expected with the controller , and is the controller an alternative to a tune ? , which I notice is no longer available from Mace .
MACE
Hey commodore665,
My sincere apologies for the delay in getting back to you.
Hey hey ,
To be clear, there are no power gains to be had with any throttle controller. What a throttle controller does is that it changes, the throttle opening characteristics against pedal displacement. Therefore the controller, conditioning the signal from the throttle pedal, such that it greater or lower throttle response, depending on how the control box is configured.
We still offer Alloytec, SIDI and LS tunes, however, we need to update our ads accordingly.
Kindest Regards,
Steve
