V
vprsvmille
Guest
Hi All,
I'm fairly new to this forum but would like to start sharing my little project. After asking around and searching for info, it appeared that I could only fit a 10" sub into my VZ ute -> either behind one of the seats or in the space next to the fuel tank under the tray. I already had a 12" carbon fibre response subwoofer from Jaycar and didn't want to fork out more money for a 10". So I bit the bullet and started measuring the space next to the fuel tank. I had heard that subs mounted in that cavity sounded quite good once the sound filtered through the three air-vents and into the cabin.
Anyway, it turns out that I can fit the 12" sub and have already cut and assembled the box to suit. The box is about 27Lt in volume and will be heavily stuffed to make the internals appear accoustically bigger.
I will be taking photos (over the next few days) of the unit and try to provide a basic guide of what I have done. If all goes well, it should be up and running by the end of the weekend.
