12 volt sockets
Discussion in 'VE Holden Commodore (2006 - 2013)' started by hatzi2508, Sep 28, 2009.
  1. hatzi2508
    hatzi2508 New Member
    ve calais v
    Hi Guys I have a VE Calais V
    Does anyone know if there is any wiring somwhere around the dash to put another 12 volt socket in. The one in the arm rest glove box is too far to use a gps system. Also is the wiring in the boot still there even tho the boot plug was not optioned.
    Thanks
  2. Turd Ferguson
    Turd Ferguson Donating Member
    N.S.W
    Disco
    there will likely be a loom at the front right of the center console for the smokers pack, which you can tap a 12v socket into
  3. Benboy
    Benboy Well-Known Member
    Hill River, SA
    2007 SVZ Wagon
    If you are only running low draw items then why not just use a double adaptor, readily available from any auto shop. Heaps cheaper and a whole lot easier.
  4. Turd Ferguson
    N.S.W
    Disco
  5. gjy46
    gjy46 New Member
    VE Sportswagon
    Yeah thought of this when ordering my new VE, so I insisted that I get the smokers pack free of charge installed!!! so now I have a 12 volt socket in the front for my gps and one in the center console where the passengers sit so i can connect a dvd player i guess. am i happy??? yessssssssssss
  6. BOY1236
    BOY1236 Crazy dude in a V8
    Saudi Arabia
    VE SS (4-speed auto)
    Aren't those suppose to be standered in all models ???? :confused:
  7. Fekason
    Fekason Fekason
    Penrith NSW
    Smoker's Pack Easiest and Best Option.
    I picked up my VE SV6 the week before Christmas last year, and headed off interstate for a holiday within two weeks. I found the single point a nuisance, as I wanted to run the GPS, one kid his portable DVD, another his I-Pod and then occasionally we had three mobile phones that might have needed a recharge.
    Subsequently I bought a front and back Smoker's pack, but have yet to install it. However it looks easy and is covered by warranty. End result is three points, which should meet all needs with an occasional double adapter if needed for mobile charging.
    By the way, I bought my pack from a Holden Dealer for much less than that Ebay price.
  8. igo
    igo New Member
    VE Calais V Series II
    Refer to my post under topic "Smokers Pack Install Help"
    you will find directions on installation of smokers pack which indicates the wiring loom connector that is used to connect the smokers pack socket - you should be able to plug your active and earth leads from the socket into it using a couple of spade connectors
    have fun
  9. SSZ Ute
    SSZ Ute Member
    08 VE SSV M6
    Go into your autopro or whatever and get a Narva 3 way connector housing set with terminals part No 56273BL. This will plug straight to the factory 'smokers pack' plugs. The terminals will be 12V, earth and illumination. Quick check with a multimeter will tell you which one.
  10. johnnylord
    johnnylord New Member
    VY SS
    Ive got a VY SS and when plugging my phone charger into the 12v socket it plays on my electrics...radio turns off and on, dash does the same and at night at times my headlights cut out...
    VERY ANNOYING!
    taken it back to holden and they 'cant find a fault so wont put new parts in'.
    any1 got a magic answer?
  11. UFO
    UFO I Believe
    MY10 VE International Sportwagon SIDI 3L
    try plugging in a different charger... sounds like the charger you are using may have a short in it. a $10 cheapy will give you your answer. if both chargers cause the same problem, you definitely know its the car 12v outlet at fault
  12. johnnylord
    VY SS
    the charger cost me $80. i tried another and did the same thing...
    took it back to holden and they said theyd test it and have a look;
    they couldnt find anything wrong and wen i got it back a wek later i had no probs!
    charger works fine and everythings good!
    i dont get it....maybe just gremlins in the electrics again!??!!!!
