15" to 19" wheels
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by aussie bob, Dec 19, 2013.
  1. aussie bob
    aussie bob New Member
    Vs Exec S2
    I'm getting a set of 19" wheels put on my vs on Saturday. I currently have 15" interceptors on it. Just want to know how much my speedo will be out at speeds from 40km to 110km
    Thanks for any help
  2. VS 5.0
  3. hakhawk
    tyre width/profile will dictate difference in speedo reading.
    use the link above, punch in the tyre profile you have on the car now (eg. 205/65r15), and what the new wheels have (eg. 235/40r19).
  4. corhijasna
    corhijasna Member
    Portland Victoria
    if you get the right tyres fitted,eg profile etc there shouldn't be a lot of difference
  5. jyplht
    jyplht New Member
    Hi , your rolling diameter will almost be the same , corhijasna hit the nail on the head with his comment , also a good way to check it via a GPS ( sat nav ) as some have your current speed , I used one for my VS , I'm running 15x7 interceptors ( ex cop rims ) and 225/60/15 tyres and my car at 104 kph via the speedo is actually 100 kph via the GPS , there are places that can fix your speedo via a black box unit and a GPS unit then they adjust it and then it's fixed at the correct speed , just remember one thing , each time you change rim size you'll need to re adjust the black box settings .
    I know this a long reply but i hope it's useful , I used to have to explain this to customers for years as I spent 13 years in the tyre industry ..... Good luck
  6. aussie bob
    Vs Exec S2
    Thanks for all the replies back. Can't remember what the exact tyre size is but I'll use that link Saturday to give me a rough guide. jyplht would a jaycar speedo correction kit be easy enough to use or could I get my memcal re-tuned?
  7. VS-S
    Man just get what I have. They're 245/35r19.
  8. ducker85
    ducker85 Active Member
    Narnia
    09 VE clubbie R8
    It would be cheaper and easier to buy the correct tyres as 205/56R15 and 235/35R19s are within 1km of each other {facepalm}
    225/65R15s will throw your speedo out further then 19s with correct tyres
  9. _R_J_K_
    _R_J_K_ Well-Known Member
    Zenki S14
    Speedo data isn't processed by the tune/ECU on the VS, gotta get the corrector kit. Make sure you tap it in before any trip computers you might have though.
  10. ducker85
    Narnia
    09 VE clubbie R8
    Although true there's no NEED for a speedo correction kit
  11. aussie bob
    Vs Exec S2
    So I got my wheels put on 19x8 with 245/35 tyres and now when I go over a bump in the road the tyre hits the left front strut tower. Is there anyway to fix this?
  12. hakhawk
    ideal = get smaller/narrower tyres or wheels with lower offsets
    dodgy and not roadworthy = get 5mm spacers
    slightly less dodgy depending how competent you are = massage spring seat to clear the tyre where it rubs
  13. immortality
    Sth Auck, NZ
    You would probably be fine with some 235/40's.
    If it's only doing it on the one side it might be indicating that the wheel bearings are getting a bit sloppy. I had this problem on my VN going for 14's to 17's. Fortunately on the VN I just removed the bearings, cleaned them up, re-greased them and then set the bearing pre-load to suit the larger diameter tyres which unfortunately isn't possible from VR onwards with the sealed bearing hubs.
  14. IRON8
    IRON8 Let It Rip
    Auckland, West Harbour
    'VTank SS , VG/VR Ute
    just bring the camber out a little bit, 5 minute fix
  15. immortality
    Sth Auck, NZ
    ^^^ That's right. You can adjust the camber at the wheel hub.
  16. IRON8
    IRON8 Let It Rip
    So just slightly loosen the two nuts and wined in the camber adjuster half a turn clockwise, tighten the bolts backup, throw the wheel back on and test. if you find the car starting to pull to that side , just do the same to the other side. Would recommend getting a wheel alignment but it shouldnt be too bad..
  17. aussie bob
    Vs Exec S2
    heres some pics of how it sits now. will the camber bolt help out this? the tyre doesnt rub on the side just that round part where the spring sits in
  18. VS-S
    Maybe you're just taking bumps too fast.
  19. IRON8
    IRON8 Let It Rip
    you have plenty clearance there.. no signs of the tyre rubbing on the shock either.. are you sure its not guard rubbing??
  20. mr calais 5.0
    mr calais 5.0 New Member
    victoria
    vy s 2003
    How close is the tire to the guard and can you turn lock to lock with out scrubbing?
