19'' SSV wheels on VT Calais
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by CJ_Calais, Sep 6, 2012.
  1. CJ_Calais
    CJ_Calais New Member
    Supercharged VT Calais
    Hey guys i know this has been covered bulk times but ive come across a set of 19 inch SSV wheels for my calais at a dirt cheap price in brand new condition and i need a direct answer straight away.
    All i need to know is will they fit onto my VT Calais with 245/40R19 tyres after I machine the rim? no camber kit or anything? the car still has standard suspension
    Also eventually down the line i would like to lower it with either SL's or SSL's. will i need a camber kit for when i do this?
    Thanks heaps lads
    Chris
  2. blocka
    blocka EXC35
    Sunshine Coast, QLD
    VT S L67
    I have them on mine and machined the lip with a die grinder and they are fine. However I got Tyres to suit as from my belief the tyre profile for the VE's cause the problems.
  3. FATMOE
    FATMOE New Member
    VY Clubsport R8
    Yes they will fit once machined, no camber kit needed if stock height and yes you will need one unless you like buying tyres. I would recommend a 235/35 or 245/35 over the 40 profile though.
  4. CJ_Calais
    sweet thanks heaps guys, i plan to lower the profile when i get some money but for the time being im going to need to leave the tyres they come with.
    If i lower the profile what is the widest i would be able to go on the ssv rim fatmoe?
  5. FATMOE
    FATMOE New Member
    VY Clubsport R8
    You can go a 265 if you want or even more but then you have to start modifying the rear guards to suit.
  6. 87LAG
    87LAG BOOSTED 6 FTW
    THE SWITCH
    VX S S2 AUTO RAPTORCHARGED
    Its not hard to phone a decent tyre shop rather than starting a useless thread thats been done to death
    the facts are that yes once machined will go on but tyres are no good they will more than likely hit the strut at the front and more importantly be illegal for the car u will need to change over to a 245/35r19
    cheers and gl
  7. GAMBLR
    GAMBLR More trouble than u think
    Whyalla (yawn), South Australia
    '04 VZ Calais LS1
    AS 87LAG has said. Also, you will need VE style nuts to suit the VT, or they will vibrate loose. Happened on dad's VT when we didn't realise we needed new nuts.
  8. CJ_Calais
    About how much will they set me back and where can I get them from?
  9. 2O4TS
    2O4TS Member
    Qld
    VT 9C1
  10. kangavxss
    kangavxss New Member
    2002 VX SS
    If u use 40r tyre profile your speedo will be out, so u need to get 35 profile for a 19inch rim
  11. CJ_Calais
    Sweet as, i can still drive on the 40r's yeh? illl just have speedo troubles and maybe scrubbing on the front strut on full lock?
  12. GAMBLR
    '04 VZ Calais LS1
    You won't be able to drive with a VE size tyre. It hits the front strut more than just full lock and scrubs badly on the rear.
  13. sharp0
    sharp0 New Member
    VT S Pac S2 Manual 2000
    Hello, I have just currently done the same thing as chris. Although my 19's are Redline VE SSV Rims with the pre drill to fit my Vt S Pac.
    I have stock as sh!t suspension, I need to replace the tyres on them as they are unroad worthy there 235/35r19s
    Just seems the front sits alright but the rear looks like it has tones of clearance?
    Im pretty new to this
    here i have a photo with the stock wheels on it then the 19s
    the stocks are 225/50r16s
    Now with the 19s
    Please give me your thoughts on what you reckon i should do to make it look better?
  14. VS-S
  15. sharp0
    sharp0 New Member
    Like SL or SSL? front and rear or just rear? the clearance of the tyre from the front sturt is only a finger and a half if that.
  16. colourmesilver
    colourmesilver New Member
    Brisvegas
    VT1 98 SS 195i 5.0L 304 HSV ENHANCED
    hones out ya diff, less power and is just a show pony leave ya 17's on or whatever.
  17. colourmesilver
    Brisvegas
    oh you only have a 6, nah looks good man
  18. VS-S
    Super lows all round.
