19" x 8 maloo wheels on a vs ute!
Constatiner
Mackay
vs commodore ute Series 2
Hey all,
Just wondering if these will fit on my ute? it has been lowered an inch in the rear.
I do plan on carrying 2 x 250CC Motorbikes , What size tyre profile should i go? what width tyre should i go? will it scrub out bad with the motorbikes loaded in the tray?
justbad4you
IF YOR NOT A HOLDEN
MELBOURNE S/E BAYSIDE
97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
http://forums.justcommodores.com.au...-vyii-maloo-wheels-18x8-vrss-yes-100_3345.jpg << fitted on the ss sed....as for scrubbing(heavy duty shocks should help out some there) if you springs aint to low already
Hey all,
old mate
33
Gippsland, Victoria
www.facebook.com
VB Sedan / GU Patrol
if the rim offset is 48p you will get scrubbing in the rear when it flexes up. it rubs on the inner guards.
i wouldnt go any wider than 235, just for piece of mind with the clearance between the inside of the wheel and the strut.
justbad4you
IF YOR NOT A HOLDEN
go low profile tyers
Hey all,
Constatiner
Mackay
thanks all i dont know what the offset is but if it helps heres a pic of the wheels im getting.
justbad4you
IF YOR NOT A HOLDEN
those will fill out the arches pretty well,
as OLD MATE SAID>>>>>>>i wouldnt go any wider than 235, just for piece of mind with the clearance between the inside of the wheel and the strut...OH AND YOUR SPEEDO WILL BE OUT NOW AS WELL
commycrew
SA
VS V8 Ute
Hey mate, just thought I'd let you know. on my Vs ute I am running 19" rims with 245/35's and don't have a problem. On the front it was slightly against the strut but just screwed the camber out a bit and now it's clear. Under the back is Close (my ute's almost on the bump stops) but it all fits and even with a load in the back doesn't change a thing! Hope this helped!
Constatiner
Mackay
thanks very much guys , they fit perfect appreciate it, will post pics of them on my ute tommoro
Constatiner
Mackay
here it is.....
