1980 VB SL Commodore
ncass11
cairns, QLD
'81 Diesel Hilux / '75 Landrover series 3
so im just looking around for a timing cover for the 202 and then i will put it back together, i found a panel beater to do the welding for me and quoted me $600 to do the lot, best not to do it my self,
boganc
Donating Member
salt ash nsw
vb commodore
Hi there big rust job i would do it yourself its the only way u will no its cut out most panel guys will ruff weld and bog other then that find a better shell [ ebay] see them stripped out and lost interest all the time last one i got had a full 2k respray that was old paint done in 2000 i payed $251 on ebay witha $1000 rubber kit and a boot full of new parts no rust paint was great all pro panel beater job any way have a go learn some skills
ncass11
cairns, QLD
i have done fk all to the VB, i have been working on the cruiser and dont have the time or space for the commodore. But I have just started renting a shed for the commodore so i can rebuild it in, i hope to move the commodore there soon. i have a mate that said he knows someone with a good vh shell so im going to take a look at it tomorrow to see if it has any rust and how much he want for it, then i can swap everything over and put the v8 in it then i dont have to worry about fking around with rust
*uwishn*
Holden special vehicles
sydney
vl walkinshaw(replica)nissan navara d40 st-x turbo
a bit of dedication going into this old girl,i like it.
HAZZA-VN
BLACK VY SS :)
Yeah I'm Looking forward to see this new beast and how you decide to go with it.
VBRED
Melbourne - SE
Black VK Calais 333 Pack
Mate I think that is the best suggestion yet. You will be for ever chasing rust in that VB.
ncass11
cairns, QLD
i have taken a look at that VH and it seams to be good, fk all rust besides in the spare wheel well and i cant find anything in the door sills, boot sill or around the windscrean.
i thought it was just a rolling shell but it has a 253 and trimatic in it not bad for $500, need to find a way to drag it to my shed
I have a good feeling about this one
ncass11
cairns, QLD
got both of the cars to my shed, fired up the vh first try and it sounds beautiful but i will still swap it with the 304
its got power steering and aircon, rear disc brakes
the car slid fowerd on the trailer and did some demage, ill just swap it with the vb
Darren_L
Toowoomba, Qld
VH SS
the body on the VH appears to be fairly good (apart from the front where it hit the trailer!)
Get some paint on it and it should look good
the engine note, will generally come down to the exhaust, so it shouldn't really change much when you swap the 304 into it.
got a lot of work ahead, so it's probably a low priority, but make sure you replace those strut tops/bearing plates. They rubbers looks like they are about to pop
all the best with it!
ncass11
cairns, QLD
my mate welded in the front from the vb to the vh and im currently welding some rust in the boot, once i sell the motor and tranny out of this then ill clean the engine bay and shove the 304 in there, im not sure if i should go carbie or not, with carby there will be less fking around but the manifolds are bloody expensive, but for an efi set up i need a loom and i gotta fk around with wires, and god i hate wring.
