oh ****, you have two metering blocks
far out man, you sure you wanna be using that carby? two metering blocks means you will have to set up 2 powervalves. anyways you need to set each screw the same, so what you do on one, you do on all 4.
great. now we need to figure out what powervalve you need for the secondarys... unless you plan on blocking it off and using bigger jets? i would. saves a lot of dicking around.
so best start from the start:
turn all the screws in till they [gently] bottom out. then unscrew each one 3 turns this time. (half turns, so 540 degrees) get it started and running stable. make sure your vacuum advance hose is disconnected* set idle in drive @ 900 rpm, set base timing to 10 deg btdc and it should start running properley. when you get it running reasonable, turn it off, turn all the screws in then out 2 turns (360 degrees) start the car, raise the idle if necessary to stop it stalling, turn one 45 degrees, then turn all the same, stop look at the guage for 3 seconds, watch the fluctuations and guess the middle. so if its going from 8in to 12in then memorise 10inches. stop turn all 4 screws out 45 degrees, then watch the needle. repeat.
*make sure you are using ported vacuum for the dizzy vac advance, there will either be a port on the front of the base or on the drivers side of the front metering block. DONT USE FULL VAC!! lol, i learned the hard way with that one.
