1989 Vn (Manual) Wagon RIP CJP
poelwyk
Werribee Victoria
BA XR6 Turbo /VN V6 Wagon(soon to be V8)
put the clubbys on it
i also started fitting the bay off
i fitted a ve horn
just some over all pics of here
testing out lights
fitted some more stuff
chrome handels
statesman power outlet
now some issues i started to pull down the motor to find this so i was on the hunt for a replacement
i then was given a lsd and 345 diff from a ef/el so i removed the center for the wagon
Now to yesterdays update i was given cj's subs back (the ones with paint on there) trying to work out what to do
poelwyk
Werribee Victoria
some updates
brought another motor
then i stared the paint it and cleanup
fitted the blue leads from the other motor
painted the bananas black
pulled the sump off to have a look
pulled the rocker covers off bit of buildup in there but no a issue as ill be pulling my other heads and cams and stuff on it in a later date
brought a blue house kit
i also got a new coolent bottle
i started to repair the vn 5l look that was looking a bit worse for it
fitting new sump gasket
re fitted sump
now yesterday was a big day
pulled the front end out and swaped some of the stuff over to the v8 kframe
V6 kframe
bits that are getting use used
a mate giveing a hand to pull down the bits from the vs v8 kframe
v8 kframe before cleanup
how the car was fitting for a bit
how the kframe turned out after
and this is where we are at now the v8 springs went in with the kmac tops motor was droped in and bolted in ... iv also go to swap the racks over as the vs one will not work with the vn as its longer
P plater
the immortal misguided one
24
Elizabeth East south australia
1994 Ford Falcon Futura wagon/ 1994 VR Exec wagon
Love how it is going keep up with the awesome job :)
poelwyk
Werribee Victoria
another update :)
a little more to update
throttle cable all connected
stuffed around getting the k frame bushes in
fitted up swaybar and new swaybar links
a little overall again
with covers
Gearbox is fitted
i also used the Vs starter motor as its a quick start
fitted up a V8 fuel pump for the tank
poelwyk
Werribee Victoria
just a little update i got my hands on the trim bits that go around the back windows and a brand new looking roof liner
i also go around to fitting up the fuel tank again
