1992 Vp commodore ute lower control arm bolt
row147
NON irs :)
VP s pac utility
Hi all recently i have purchased a 1992 vp commodore "S" utility and have run into a problem
im needing to replace the lower control arm bolts on both sides that hold the control arms to the cross member (check image for the exact bolts im chasing)
what is the bolt size eg. m16x1.5 70 mm
the_boozer
no more VK
51
Shitsville Morwell
hilux
get them from a wrecker or holden dealer if any still exist I doubt a bolt bloke will have anything suitable
rambunctious
Alexandra Headland Qld
VZ Executive Wagon
No idea of size but when I need something like this I phone the closest holden dealer and ask if still available, and they may be same on later models.
Also try aftermarket because they sell lower control arms so may sell the bolts as well.
Also good fastener outlet if you can take one along for matching but tell them what it is for cause probably need hi tensile.
Last resort pedders.
