Just thought I'd post up recent progress/mods/fixes I've done.
Fitted 3.08LSD around about a month ago, along with a Nolathane rear diff mount bush, and replacement rear shocks, as the old shocks were doing absolutely nothing. LSD is great, doesn't just spin every time you take off in the wet. Diff mount bush has firmed up the rear end alot, which is also alot to do with the fact the the rubber part of the original diff mount was completely separated, and just flopping around.
Got sick of the noise and hot air coming up from around the gear stick, and due to the lack of availability of the rubber boots, decided to fit something else.
Found that Ford still have available, the boots for the EA, EB 5 speed (also a T5). Bought a boot, and retainer, and screwed that down to the floor plate. Made heaps of difference, nice and quiet now.
Fitted a 80l long range fuel tank a couple of weeks back. Actually able to go 7 days without filling up, got around 550kms last tank, but it only took 60l, so I'm going to run it down a bit further this time.
Also fitted a wind deflector to the drivers window.
Latest mod, is fitting modified fuel rails from a VS V6. Had to cut off the original mounting points, drill out the front of the rails, tap a thread into them, screw in Speedflow fittings, and mount brackets to rails.
Had a few issues with the thread tapping and Speedflow fittings, because the hole and thread need to be tapered. Ended up getting the fittings welded in.
Rails look good, gets rid of the lines running over the top of the blower (which in turn makes the blower stand out more
Thats about it at the moment.
Will get more photos up when I get a chance to take some. Waiting to get a picture of both rails, because one is back off to get a leak fixed in one fitting.
