1995 hsv Senator215i
Barbara Collett
69
New zealand
VR Senator
Recently purchased a 1995 hsv Senator 215i manual.,with engine Number VL631411.
When I took in in for servicing ,had engine number checked,it was different VG218570.
It had all the fancy 215i gear on the top.
Has anyone got the knowledge of what VL or VG mean before the number,or what size engine it is .Thanks
wraith
Hand over the dog bikkies
Demonicaland
VX V6 Berlina. 2003 VW Passat
Chuck your VIN into there and see what comes up. Nothing external on the motor to distinguish a 215 from a 185 from memory bar the different engine cover.
https://www.hsv.com.au/own/authenticate/
Brettly-2008
Vasse
SS Commodore - Ford Territory ... both camps
All the 215 stroker engines were 350cui.
BlackVXGTS
Melbourne, SE
185 VS Senators are supposed to have engine numbers with a VU prefix.
215 VS Senators are supposed to have engine numbers with a VT prefix.
185 VR Senators are supposed to have engine numbers with a VU prefix
215 VR Senators are supposed to have engine numbers with a VL prefix.
According to "HSV The Innovators 1991-1995.
Perhaps your car has had an engine replacement somewhere along the line. What is the number on the registration certificate?
Barbara Collett
69
New zealand
VR Senator
Thank you for your posts.I see the VG went into the 304 1985 manuals.
I quite agree ,some one has put a different motor in it
Barbara Collett
69
New zealand
VR Senator
wraith
Demonicaland
So it's probably a bog stock 304 with the 215 engine covers. Dodgy. Hope you didn't pay much for it.
Immortality
Staff member
Sth Auck, NZ
With the engine change it's hard to know what is actually inside the engine. How does it drive? One quick check would be to pull out the PCM and check the memcal. If the engine specification was changed the tune would have needed to be altered or it probably wouldn't drive to great.
BlackVXGTS
Melbourne, SE
Thank you for your posts.I see the VG went into the 304 1985 (sic) manuals.
There is no difference between the engine prefix for VR/VS manuals and autos as far as I can tell.
However, I seem to recall that when engines are rebuilt under warranty, and the engine block needs to be replaced, the new block already has its own engine serial number, which is identified by a different serial number to the standard range. The VR 185/215 blocks are essentially the same except for additional clearancing for the stroker crank on the 215 models.
Holden or HSV may be able to tell you whether or not the engine was replaced under warranty.
Vin999
SA
VSedanS
Some consolation info on engine prefix numbers
Police pack.(option V7X, 170kw).VG. 84-86 Police pack.
