wamboin23
Donating Member w/ Boost
- Apr 16, 2009
- 1,205
- 36
- 48
- Age
- 34
- Location
- Wamboin, NSW
- VS Calais - Cooled L67 + T56 | VF SSV Ute
Model:
- 1995 S1 VS Calais
Colour:
- Sherbrooke Green Metallic
Bodykit:
- just stock Calais
Engine Type:
- 3.8l L67
- ~8.1:1 Static CR
Engine Mods:
- Diamond Ceramic Coated Forged Pistons (3.810”, 13.3cc Dish)
- Total Seal Piston Rings
- L32 Forged Conrods
- King Bearings Main and Big End bearings
- ARP Main Studs
- ZZP XP-Hot Cam
- Rollmaster Double Row timing chain
- Polished Crank
- Cometic MLS Head Gaskets
- Ported and Serviced Heads
- ARP Head Studs
- 130lb Valve Springs
- Titanium Retainers
- Big End Bearing Oil Feeds drilled out
- FTC Carbon A2A plate
- 600x300x76mm FMIC
- ASR 7.5l Club Circuit Oil Pan
- 7 inch pod filter in enclosed box
- 82°C Thermostat
- Alloy LIM Gaskets
- MAT sensor
- 2 Bar MAP Sensor
- Deleted boost bypass solenoid
- TTT Performance solid engine mount on passengers side
- 10mm K-Frame Spacers
- Alloy Fuel Rails
- Turbosmart Fuel Pressure Regulator
- Dick’s Electronics MAFless Tuned ECU
- CAE Hi-Torque Starter Motor
Exhaust:
- Pacemaker 5039 Extractors, collectors opened to 2.5"
- Twin 2.5" 200cpi Cats
- Twin 2.5" Mufflers
- Merge to single 3" before diff
- Single 3" Resonator
Gearbox:
- T56 6 Speed Manual
- ACE Clutch and conversion Flywheel
- Short Shifter
- Mal Wood Automotive T56-V6 Adaptor Plate
- Conversion tailshaft
Diff:
- BorgWarner M80
- Eaton Truetrac
- 3.73:1 Ratio Gears
- Nolathane Rear Diff Mount Insert
Power:
- 161.3rwkw (8/1/2012 - SummerNats 25) – stock engine
- 218.4rwkw (March 2013) - rebuilt engine, intercooled, running low boost, on run in tune
Brakes:
- VT front calipers and slotted rotors
- VS-VT Conversion Brake Lines
- VT Master Cylinder
- Race Brakes Sydney VT Master to VS Booster Adaptor
Suspension:
- Munroe GT Sport Shocks/Struts
- King Springs SSL Springs
- Rear 4-point camber kit
Wheels/Tyres:
- 18" VE SS
- 235/40/18 Achilles 123S Semi Slicks
Interior:
- Stock Calais
- Modified auto console to suit manual
- VY Indicator/Cruise Control Switch
- VY Wiper Switch w/ variable intermittent dwell
- Uniden UH015sx UHF radio mounted in centre console lid
- LED footwell lights
Sound System:
- Sony Headunit
- Alpine 4 channel amp
- Alpine monoblock amp
- Kicker 12" Sub
- Audio Development Front 6.5" Splits
- DNA Rear 3way coaxials
Other Mods:
- LED globes in rear lights, and front indicators and repeaters
- Philips +100% High/Low H4 globes
- Philips +80% High H3 globes
- Genuine foglights with Philips +80% H3 globes
- Colour Coded Bonnet Protector, with Supercharged badge
- Tinted Windows
- Chrome Illuminated Door Handles
- 80l Long Range Fuel Tank
- Hidden UHF antenna
Future Mods:
- Lightweight Rotor Pack
- LS1 Throttle Body and U-Bend
- E85 Tuned
- Engine Oil Cooler
- New seats and harness
- Coilovers
It is in pretty good nick, which is the main reason I bought it, body is as straight as a die, and has all the parts in it that I wanted to fit anyway - Power Windows, Climate Control, Level 3 Dash, Chrome Door Surrounds.
- 1995 S1 VS Calais
Colour:
Bodykit:
- just stock Calais
Engine Type:
- 3.8l L67
- ~8.1:1 Static CR
Engine Mods:
- ARP Main Studs
- ZZP XP-Hot Cam
- Polished Crank
- ARP Head Studs
- 600x300x76mm FMIC
- 82°C Thermostat
- Alloy LIM Gaskets
- MAT sensor
- 2 Bar MAP Sensor
- Alloy Fuel Rails
Exhaust:
Gearbox:
- Short Shifter
Diff:
- BorgWarner M80
- Eaton Truetrac
Power:
Brakes:
Suspension:
Wheels/Tyres:
- 18" VE SS
Interior:
- Stock Calais
Sound System:
- Sony Headunit
- Kicker 12" Sub
Other Mods:
- Tinted Windows
Future Mods:
- E85 Tuned
- Engine Oil Cooler
- Coilovers
