1996 VS Taking 10 minutes to warm up
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by COWSPUD, May 19, 2006.
  1. COWSPUD
    COWSPUD New Member
    VS Commodore Acclaim 96
    Hi all,
    Upon starting my 96 VS early morning it takes about 10 minutes for the car to get up to normal driving temperature and about the same time for the heater to heat up, the heater only gets warm and not hot (my old 1991 Daihatsu Applause would only take 3-4 minutes and the heater was nice and hot) is this normal or could there be a problem.
    Normal driving temperature is between 1/4 and 1/2 way.
    Thanks
  2. fitzy2005
    fitzy2005 New Member
    Wide Bay, Queensland
    VY S2 Berlina
  3. sircruisealotVS
    sircruisealotVS Well-Known Member
    South Brisbane
    VZ LS1 Calais
    is it taking 10mins to warming up while at idle?...or 10mins of driving to warm up?
    because being an efi engine it doesnt need to sit and warm up, the best thing to do is to drive it as soon as the revs even out when you've started it up (usually takes only a few seconds)...
  4. vt1538
    vt1538 455rwhp LS3
    The Dead Centre
    VY SS S2 11.284@125mph
    Your thermostat could be seized open.
  5. fitzy2005
    VY S2 Berlina
    is it blowing black smoke out the exhuast at all?, and what oil u using? not to thick is it?
  6. COWSPUD
    COWSPUD New Member
    Thanks for your responses.
    I am driving for ten minutes going 60km/h, no idling within this time.
    There's no black smoke from the exhaust - there is 136k on clock and car looks spotless throughout.
    Not sure about oil, whatever the mechanics at Midas use.
    The car does not over-heat, half way is the highest I've noticed the temperature gauge get.
    Checked the computer for errors a couple weeks ago and got 12 (OK)?
    Will check again tonight.
    Thanks
  7. vt1538
    vt1538 455rwhp LS3
    The Dead Centre
    Your car will not overheat with the thermostat stuck open. It will only take longer to warm up.
  8. COWSPUD
    COWSPUD New Member
    vt1538,
    How do I check if this is my problem?
    cheers
  9. vt1538
    vt1538 455rwhp LS3
    The Dead Centre
    The easiest way is to remove the thermostat. This is under the housing that your top radiator hose goes to. When you remove it you will see straight away if it is stuck open. Should only take you about 10 min to remove, inspect & replace if necessary.
  10. Fekason
    Fekason Fekason
    Penrith NSW
    Slow Warmup = thermostat.
    As already advised, slow warmup is usually associated with a stuck/sticky thermostat. It can stick anywhere from fully open to somewhere between there and closed. Usually it sticks part open.
    If stuck fully open, the car will run very cool on the open road, especially in cooler weather.
    I would investigate the termostat first, before anything else.
    The fact that weather is colling down could be ab issue, but could not explain taking ten minutes to warm up.
  11. boojak87
    boojak87 New Member
    VT Series II SS 5.7L
    Now that this has been brought up I have actually realised I get exactly the same thing on my 96 vs! Heater takes a good 10 mins to warm up, and i don't know if this has anything to do with it but i'm getting fairly piss poor economy lately as well? Could a thermostat effect that? (I've had o2 sensors replaced, throttle body and iac valve cleaned, complete fuel system checked for leaks but still manage to only get 350kms to a normal exec tank).
    Cheers all,
    Boojakz
  12. ScottB_33
    ScottB_33 Go Hard or Go Home
    Nowra
    VTII Berlina Supercharged
    Yes thermostats can be very critical for a cars fuel economy, especially a fuel injected one. In fact it can play havoc with the fuel injection duration thereby using excessive fuel and greater emissions. The heater will take longer to heat up if stuck open and by the sounds of things, that is the problem. If a customer came in with this scenario I would go straight to the thermostat assembly and replace it. If it needs doing usually a coolant change is also required as it may not have been changed in a long time! Never pull one out of a fuel injected vehicle and leave it out as a car not heating up correctly can be just as bad as one overheating!!!
  13. Patrio7
    Patrio7 3Y3 K4N 5P33K 1337.
    Perth, Como
    '96 S1 VS Exec
    i've got a s1 exec and i thought that geting ~400km/tank was normal because of its smaller fuel tank?
    though admitably yes mine takes a good 5mins or so to get a hint of warm on it.
    will have to look at that on a spare day.
  14. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    Don't forget to check the vacuum operated heater hot water on/off valve - they can stick partially closed and only allow minimal flow.
  15. haloeight
    haloeight New Member
    VS Stato SII L67 S/C V6
    as stated in the owners's manual, VR/VS dont need to be warmed up
    if you are picky, rev it until it evens out then drive
  16. frenzal_tom
    frenzal_tom New Member
    Pakenham, Vic
    VS2 Berlina
    hmm interesting
    mine takes a bit of time to warm up aswell
  17. Harvs82
    Harvs82 Active Member
    Glen Waverley VIC
    MY08 Subaru Liberty GT-B & MY16 VF II SS Redline
    I would suggest that what you are experiencing is pretty normal. In the colder weather, say 10 degrees and below, I can be driving for 10 minutes or longer, and the temp gauge has only just moved off the Cold position. My parents VS is the same, they just take a LONG time to warm up, but you can still get plenty of heat in this time, its just that the gauge takes ages to register.
    I have climate control in my car, and no heat is available till the engine coolant gets to 45 deg C, so I am without any heat for about 3 minutes or so, first thing in the morning, and then it gradually increases the heat into the cabin.
    As others have suggested, have a look at the thermostat, for the sake of $12 I replace mine every time I flush the cooling system, cheap insurance in my books.
  18. haloeight
    yer my climate is the same
    pity the thermostat on the super6 is a nightmare to get to!...otherwise id do it more often
  19. patullose
    patullose Sean
    Sunshine Coast QLD
    Vr Exc 1994
    How can you check if the thermo is stuck open?
    Would this cause rough idol also?
  20. hotrod32
    hotrod32 New Member
    1995 VS Executive
    Even though a manual says that a car shouldnt need to be warmed up, doesnt acually meen that its true. All cars should be warmed up before being driven so that all parts can come up to operating temperture and that the oil can come up to its required viscosity. My 95 VS never reaches the cold part of my guage, as its always below and i feel that it hurts my economy greatly along with engine life. im getting half as many miles out of it then i did out of my VN which never seemed to have any problems warming to about 1/4. I will investigate this firther.
