1996 VS Wants to start but no spark
Racer05
60
Portland
VS Belina
Hi All, Yesterday my old but reliable VS hit some bumps going over a railway line and the engine juswt stopped. I coasted away from the crossing. once stopped . i put it into Park and tried to start the car. I hear the pump and check some things in case a cable has fallen off. I go towed back home. Today i changed the coil pack and still no luck. its the only car we have.
Any ideas for me to look for. Thanks
losh1971
North Tas
VE Series I SS Ute
Might be the DFI or crank sensor both those will leave you stranded.
losh1971
North Tas
VE Series I SS Ute
Scan codes before replacing any parts.
Racer05
60
Portland
VS Belina
Hey Guys, Thanks for your help. I Tried a couple of Local Auto elecs they either haven't returned my call or unable to help. I was told to get someone out would be few hundred dollars just to check. Anyway i found a crank angle sensor for the car and replaced it. It still wont start. I am trying to get a OBD1 cable for future.
Racer05
60
Portland
VS Belina
Thanks Wozza for the link I did the safety pin test = Code 12 (1-2) System OK. when i cranked it over t almost started. Although i can hear the pump working i might check the fuel line next. Cheers
losh1971
North Tas
VE Series I SS Ute
Do what Wozza suggested using a paperclip. You need a ALDL otherwise and it will set you back $130 with software.
losh1971
North Tas
VE Series I SS Ute
Might be a blocked filter. Also try tapping the tank with a broom handle while cranking.
