1997 Series II VS Calais Fuel Tank
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Sara Pax, May 31, 2008.
  1. Sara Pax
    Sara Pax Banned
    1994 VR Wagon and 2007 6 litre Calais V
    Hi Guys,
    Would this car have the 59 litre tank or the 73 litre tank fitted
    And is there any way to tell from looking at it
    Thanks
    :dance:
  2. Surfwagon
    Surfwagon Well-Known Member
    Sydney/NSW
    AMG Mercedes C63 Wagon
  3. PanthaVS
    PanthaVS New Member
    VS S-Pack SII
    Generally, V6 = 59ltr and V8 = 73ltr
    what size engine is the calais? and if you really wanna be sure, let the car run till the fuel light comes on, then put 27ltrs in it.... (Litres... NOT dollars) if it sits around half on the gauge, then its a 59ltr... if it sits about 1/3 up the gauge... 73ltr tank.
  4. Sara Pax
    Sara Pax Banned
    Its a V6
    I had to put another dash in it as the original one had lost its bottom LCD display so there was no KMS reading
    I noticed the original one was set on 80 litres on the fuel gauge switch on the back of the dash.
    But the other day the fuel tank was just about empty and i could only get 58 litres into it
    :bang:
  5. PanthaVS
    PanthaVS New Member
    VS S-Pack SII
    if thats the case, try flicking the switch on the back to the 60ltr setting....
  6. Summer-Sickness
    Summer-Sickness 2005 VZ EXEC
    Rockingham, Perth
    05 VZ Executive
    is the switch just on the back of the cluster?
  7. STEALTHY™
    STEALTHY™ So Wet For You!
    SA - The Roadworks State
    I thought it was 63L and 80L?
    Yes, the switch is on the back of the cluster.
  8. PanthaVS
    PanthaVS New Member
    VS S-Pack SII
    agreed! +1 :D
  9. Fekason
    Fekason Fekason
    Penrith NSW
    Look for plastic tank guard!
    The fuel tanks in the VS are the same as earlier Commodores. However, the specification reduced the quantities to those that can reasonably be held.
    To fit 63.6L (14 imperial gallons) into a small tank takes hours (poetic licence) of drip feed, and is not recommended as fuel can flow back into the charcoal canister if the car then sits in the sun.
    Thus the old 63.6L tank is listed as 59L and the old 80L tank as 73.
    The long range tank sits lower, and so is fitted with a plastic stone guard. That is usually the best way of being sure other than draining the fuel and seeing how much is required to fill it up.
    Being a V6, it is almost certainly a 59L tank, though the long range tank was an option on the VS.
  10. STEALTHY™
    I figured as much, but before this thread, i have never seen those quoted numbers, only 63 and 80.
  11. Scooter79
    Scooter79 Well-Known Member
    South Coast, NSW
    VSII Calais supercharged
    If the tank is from a VS with a V6 ecotec motor it had a 59L tank. If it had the supercharged 6 or V8 it had a 73L tank.
  12. JD
    JD Donating Member
    Deep South, SA
    1.6L Turbo Holden Croooooooooooze
    being a calais wouldn't it have the long range tank standard? ( a mate of mine has a VS Calais V6 with it. )
  13. Scooter79
    South Coast, NSW
    Not if it had the ecotec motor.
  14. joshooaahh
    joshooaahh New Member
    melbourne vic
    vp berlina lx
    wouldnt u just wait til its almost empty then fill it up and see at the petrol bowser how much fuel went in?
  15. ephect
    ephect Donating Member
    VS Acclaim V6
    but they had the problem that the gauge could have been wrong, showing its almost empty and it may have had 20lts
    get the VIN number, ring holden n ask they'll tell u straight up
  16. JD
    JD Donating Member
    Deep South, SA
    It certainly does have the ecotec motor, makes me think that it may have been changed at some point now.
  17. VSIIBerlinaL67
    VSIIBerlinaL67 New Member
    VX SS M6
    on the back of the cluster is says 60L and 80L,
    just fill it up and see how much it takes.
  18. Sara Pax
    Sara Pax Banned
    I left it on 60 Litres and when the gauge showed nearly empty without the low fuel light coming on i filled her up and it took only 51 litres
    Low fuel light gives you 8 litres left
    So i think its a 60 litre tank
    :thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::thumbsup:
  19. STEALTHY™
    I've never seen my low fuel light.
  20. ephect
    VS Acclaim V6
    sounds about right!
