1998 HSV VT GTS - My Toy
Mistikal
Hoon in a Deluxe Pack
WA
VX Berlina
Model: 1998 HSV VT GTS
Colour: Raven
Bodykit: Standard HSV
Engine Type: "Iron Lion" 5.7L Harrop Stroked 350ci
Engine Mods: Zip!
Power: Touch more than standard
Exhaust: Pacemaker extractors, aftermarket cats and cat-back
Gearbox: Getrag T56 - old school
Diff: Hydratrak 3.45:1
Brakes: Standard HSV "330mm"
Suspension: Monroe standard fitment replacements all round, standard height springs
Wheels/Tyres: 18" HSV VT GTS, or choice of 19" HSV VZ2 Maloo R8
Interior: Standard Cloth
Stereo: Standard CD Player
Other Mods: ... I am trying to undo the mods!
Build Period: Purchased January 2018
Cost: Lets not go there
Finally was in a position to buy a car I've wanted since I was a young lad, and made the commitment to purchase when the time was kind-of right. This car popped up in a handful of smaller Facebook groups as an EOI, and I made contact with the seller in Melb and got chatting over a few weeks. Long story short, car was chucked on a train and sent across the rock to Perth, and is slowly undergoing transformation back to stock standard, where it is deemed appropriate without throwing pointless cash at it.
Here we have it on the day it arrived home - Nanna approved; she even added her own little seal of approval dent with her walking stick o_O
In the back yard after a wash - looks super great in these photos, but it does need a proper detail (you can't see the swirl marks or the cobwebs in the paint)
Here on it's first outing to Custom Cars and Coffee on a phoneworthy (movement permit). Fitted the 19s for the day to gauge reactions, think I will go back to the 18s even though I do like the 19s. I have had the image altered to delete the towball, which is definitely going.
To do:
- Motor out, find oil leaks; looks like front timing cover and oil pump
- Replace front and rear shaft seals in the gearbox
- Fit new complete clutch kit, skim flywheel
- Few odd jobs to get it ready for...
- ... registration!
- Replace the front bar with the very good spare I have, needs prep/paint
- Removal of the towbar package
- Replace the rear bar with the very good spare I have, needs prep/paint
- Find a very good rear wing with no damage/cracking, mine is cracked at the bases
- Drive the pants off it
afstruct
Warners Bay
HSV VS Maloo , 2002 Monaro
Nice, I remember about 3 or 4 years ago tormenting myself, seeing a gts vt series 1 for sale ( so wanted to buy it ) from a dealer 124000 kms , all options, leather , sunroof , big brakes , just under 17 k ( try and get one for that price now!!).
This or a senator signature vt series 1 = last of the real true Aussie powered commy muscle cars
Mistikal
WA
VX Berlina
Bolted the standard wheels back on it the other day, much happier now.
Clutch master cylinder has crapped out, so need to replace that now also... the list of items to do for rego is getting shorter!
Gunnie
Motueka, NZ
HSV VT GTS
Nice car mate. Ive got a Bermuda blue one with all the goodies bar the big brakes. It has cats delete on it, so sounds very nice!
Mistikal
WA
VX Berlina
Been a long time between drinks on this thread, figured it was high time for an update.
Motor has been out, nice and fresh now - essentially had a full rebuild except the heads were not removed from the block, bores were not touched, and original piston rings retained as they were still in tip-top condition. Crank was polished, fitted new crank bearings, timing chain kit with guide, every seal and gasket replaced aside from the HGs, new injectors, new dizzy, new coil, rebuilt the ignition module, whole swag of sensors replaced, new engine mounts, all heater hoses and tap replaced, and few other things too. Alternator still needs to be replaced, it works but it is noisy.
New "standard" replacement clutch kit fitted - did not bother with an upgraded clutch, as the rest of the car is stock. I don't plan on beating up on it any time soon, and it'll certainly never see the likes of a race track, so no point really.
In preparation for registration, the following work has also been done:
- Main diff mount replaced as that fell to bits on the hoist
- New tie rods and ends
- New castor bushes in the front
- New lower control arm bushes, inner mounting bush and Z bar bush
- New front wheel bearings
- New front struts, KYB Shortened
- New front strut tops and bearings
- New Nolathane sway bar bushes, kept existing link rods
- All rotors skimmed and still well within tolerance (they are just standard rotors, not slotted/etc, will replace eventually)
- New brake pads fitted
- Clutch master cylinder replaced, seals failed
- Brake light switch replaced
- 2x new tyres on the front, existing were 12 years old!
The rear tyres need to be replaced also, however I need to fit a camber kit in the rear first - there is no point chucking new tyres on the rear if the insides are going to be destroyed! I am tossing up sourcing a late-VZ rear cradle with the toe-link adjusters, as surprisingly even VT1 had mounts on the body for the links to bolt to! If I do change the cradle, I won't bother with a camber kit, as I have no desire to lower the car beyond how it came from HSV.
I managed to source a standard HSV VT cat-back exhaust in great condition which has now been fitted to the car too. Nice and subdued, quiet when I want it to be, and cranky when I give it the jandal.
I have also fitted a VT1 Calais rear garnish, retaining the HSV boomerang on the rear also. Simple mod, just gains the tail lights in the rear bootlid, looks standard when headlights are off.
Not yet done anything else on the exterior of the car, it still needs a proper going over by a professional. I have sourced replacement bumpers which will be painted at some point in the (distant) future.
Interested in selling it Mistikal?
No... well... not yet. Shush you! IF and its a mighty big IF it were to be put up for sale, it won't be until the car is Mickey Mouse with not a cent to be spent on it.
VK355stroker
22
VK SL Commodore
Message me directly if you’re ever interested in selling it. Cheers mate!
vywgn
1967 Holden HR Premier Wagon / 2015 VFII SV6 Sedan
Putting a VXs2-VZ cradle in would be a smart move but I'd still get a camber kit installed to the outer bushes so the camber can be improved to take the strain off the inner edges
