1gze blower in vr
S
sickbuick
Guest
I have seen a vn with a toyota 1gze blower. I have found out I can pick one up for $400. Does anybody know what other modifications will be needed? Besides the obvious of getting it to fit and doing the chip. It would only run about 4 psi.
J_D
Ipswich. QLD
VN S1 and VS V8 Statesman
Rising rate fuel pressure regulator and a drive belt that will fit. Cant think of anything else ATM too early in the morning.
VN_Luke
ƃuoɹʍ ʇsnɾ sı sıɥʇ
Mexico
Get in the ute
it will run fine with a bit of a tune and just bolted on to the side of the motor and being driven by the belt.... of course, the more you modify the more you will get out of the setup...
you should look into at least a decent sized exhaust and some headers
then when you get bored, up the boost, retune, sort out enough fuel....
then when you get bored again, up the boost some more, retune, sort out some form of cooling :p
S
sickbuick
Guest
Thanks guys. The only reason i want it is because you can apparently connect a blow off valve to it and i just want that cool sound the cheapest way. Also the extra bit of power wouldn't go unwanted. There is also the point i can lift the hood and tell people it's supercharged! So all i would need is a retune, new belt and the blower just to get it running?
5Litre
VS Series III ute 5.0M and VL Berlina Turbo Wagon
Have a look at the Castlemaine Rod Shop kit at:
http://www.rodshop.com.au/superchargerholdv6.htm
It's $2000 which may seem expensive but it is a straight bolt up kit so unless you're equiped and able to fabricate the brackets etc. it may actually work out cheaper.
But if all you really want is that horrible wanky psssh then check out :-
http://www.takakaira.com/accessories/nightpager/nightpager.html
or
http://autospeed.drive.com.au/cms/A_2188/article.html
but serious mate if people see this under your bonnet they're gonna lay heaps of **** on ya.
LisnM8
VS Statesman 5Litre
mate i remember seeing something you plumb into the exhaust system that makes the blow off noise, cant remember were unfortunatly.....anyone else know what iam on about?Or was i dreaming......Or even cheaper still record a turbo car, invest in a stereo and turn the dial the the max..... lol:D
The Darkness
Junk Yard Dog
Ipswich
Charged VT V6 A4
yeh man on ebay for 29 dollars i believe. dont think it would suit the rumble of the holdens tho
5Litre
MadE21
slapministrator
www.eurocca.net
VZ SV8 6M&BMW(race car)
hahaha you have got to be jokin right?
we built the whole thing for under $600, runs a BOV(or it blows hoses off)
this was on a VN, ran a saab turbo belt and cut a groove off:)
The Darkness
Junk Yard Dog
Ipswich
Charged VT V6 A4
these two sites from my post above
http://www.takakaira.com/accessories...ightpager.html
or
are for 'electronic blow off valves'
All they do is make the noise. I think this is the kind of crap item you saw on ebay.
P.S. as the motor is a V you may need to fit two of these to get the full performance benefit.
yeh i agree they are crap. but these ones bolted onto the inside of the muffler. somethin to do with pressure build up. personally i wouldnt bother tryin to get the pwsssh sound. much prefer rumblin
