2 Questions on holden crewman utes
VP_SV6
somewhere in geelong victoria
1992 vp Executive sedan
hi i have 2 Questions about the crewman
1 the size of the ute tub on the inside
2 the size/length from the cab to the wheel arch in the tub is
anyhelp asap thanks.
bcw61
Northern suburbs of Adelaide
VZ 2005 Executive Wagon
The attached file might help for the tub size.
Unfortunately, there does not appear to be any dimensions for the cab to the wheel arch.
VP_SV6
thanks BCW61
2 more things to ask
how long between wheel arch and cab, how up right are the back seats, much room in the cab
and
also how much room when front seats right back in the back row.
thanks
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
Go for a drive and find a car yard with one and measure it up......
bcw61
Unfortunately, they are all the dimensions I have.
As suggested by Not_An_Abba_Fan, you will need to carry out actual measurements on a vehicle, as the dimensions you require will vary according to the individual component locations, and the range of adjustments they have.
