I’ve never seen a winning lotto ticket but I know they exist just like that document that references the label exists…
If that’s not enough, read the following doc, section 4
https://www.infrastructure.gov.au/s..._LS_Tyres_Suspension_Steering_Nov_2015_v4.pdf
4 BASIC MODIFICATIONS WITHOUT CERTIFICATION
The following modifications may be carried out provided they do not affect compliance with ADRs, the in-service provisions of the AVSR and provided they meet the general safety requirements specified below for each modification:
4.1 REPLACEMENT TYRES ON STANDARD (OR MANUFACTURER’S OPTIONAL) RIMS
Some tyre sizes have become obsolete and are no longer available. Equivalent replacement tyres with different size designations may be fitted without specific certification under this Section.
Every passenger car manufactured after 1972 (ADR 24) is fitted with a tyre placard that contains information on original and optional tyres and rims for that vehicle model.
A motor vehicle under 4.5 tonnes GVM which is required to comply with ADR 24 may be equipped with tyres other than those listed on the tyre placard provided that:
- the load rating of the tyres is not less than the lowest load rating listed on the tyre placard of the vehicle or equivalent variant of that model vehicle;
- the speed rating of the tyres fitted to a passenger vehicle is at least 180 km/h (S) when the tyre placard requires a higher speed rating than S;
- the speed rating of the tyres fitted to vehicles with special features for off-road use of at least 140 km/h N when the tyre placard requires a higher speed rating than N; and
- for all other vehicles a speed rating of at least 120 km/h.
- In special circumstances, the speed rating may be less than the ratings specified above if the speed rating of the tyre is more than the vehicle’s maximum speed. This will need to be confirmed with the Registration Authority.
Thats the national regulators view and rather clear that lower speed rated tyres can be fitted… and without certification is you read the earlier parts. But state rego authorities always have the final say since nationalised rules aren’t fully nationalised
and there is I rony just in that
The above NCOP 11 clearly states certification isn’t needed as does the previous NSW doc when rules around lowered tyre speed rating are followed, the difference is in the allowed speed rating itself. NSW doc is a mess in referencing vehicle top speed, NCOP is not.
Interestingly in S.A it seems that the NCOP view is followed as the following website shows
https://www.sa.gov.au/topics/drivin...-standards-and-modifications/wheels-and-tyres
Tyres
The overall diameter of a wheel and tyre fitted to a vehicle must not be more than 50mm (4WDs) or 15 mm (other vehicles) larger than the largest tyre size listed on the tyre placard and not more than 15 mm less than the smallest tyre size listed on the placard on all vehicles.
The following requirements must also be met.
- The tyres fitted must be suitable for the rim. The tyre retailer should have information about matching tyres and rims. Specifications for overall tyre diameters are listed in the Tyre and Rim Association of Australia - Standards Manual.
- The tyres must be free of any apparent defect that could make them unsafe.
- The replacement tyres must have a load capacity not less than the lowest load rating specified on the tyre placard.
- The speed rating of the tyres fitted to vehicles for off-road must be of at least 140 km/h ('N') when the tyre placard requires a higher speed rating than 'N'.
- The speed rating of the tyres fitted to a passenger vehicle must be at least 180 km/h ('S') when the tyre placard requires a higher speed rating than 'S', for all other vehicles a speed rating of at least 120 km/h applies ('L').
- Tyres fitted to an axle of a vehicle must be of the same size and carcass construction
So again, even in S.A as long as tyre diameter increase or decrease is within allowed limits, S rated tyres can be fitted even if higher speed rated tyres are listed on the tyre placard while tyre load ratings can’t ever be downgraded.
On all other points I agree with you except the need for certification if only tyre speed rating is reduced. Comments around AS/NZ standards are just ignoring the facts before you around modifying speed rating. Just accept you may have learnt something (if anything that national and state modification documents are a mess and don’t always clearly agree as fed and nsw docs show)
