2000 VT 157xxx kms knocking coming from rear
choccojosh
Port Augusta, SA
2000 VT Executive S2 sedan
hello everyone,
as the title says I have a 2000 VT sedan with 157xxx kms which has a knocking sound coming from the rear, have checked other threads and found no solution, the knocking sounds like when you're driving at 10kph then you slam the gear stick into park, it makes those noises.
notes about the car:
3 months ago there was a metal on metal rubbing sound coming from the front left wheel but grandfather put some grease somewhere and it stopped.
3 weeks ago put MACE 25mm manifold spacer on
4 weeks ago fitted 2.5inch redback catback exhaust without rear resonator
5 weeks ago put stockies on the back for cheap alternative to camber kit
have not done any maintenance because only travelled under 5000km since buying the car
any ideas anyone?
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
Hmmm. Maybe your new exhaust has come of the hangers and is banging on something?
choccojosh
Port Augusta, SA
its not the exhaust, have already checked that.
at 5kph it starts as a dull thud every 6 seconds then as you are accelerating up to 90kph it increases to around 10 knocks per 2 seconds
Tasmaniak
Not a valid input....
41
S.E. Melbourne
www.ranjinstallations.com.au
Obviously something rotational based upon your timing, I would say tyres.
Is it consistent timing?
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
It does sound rotational as Tas has suggested.
Are you absolutely sure your tyres are ok?
Jack up each corner and have a good look at the inside walls for any bulges or evidence of tread delamination,
as this can be hard to see from the outside.
If this keeps happening, I have a feeling that something is gunna go bang.
choccojosh
Port Augusta, SA
the outer walls are kind of bald but the inner walls still have the rubber nipples lol
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
If they are bald and worn down on the outside, the tyre/s could be stating to delaminate. In other words, the tread is coming away from the carcass of the tyre.
I'd be getting new tyres as soon as possible, not only because of bald tyres, but also if the tyre/s delaminate while driving, especially at high speed, it could be catastrophic, not only for you, but the person driving behind will get a face full of rubber.
choccojosh
Port Augusta, SA
I put the stockies on the back because my 17's were camber worn badly, upon checking the tyres closely there's only the rear right that has a bald wall. I doubt bald walls could cause knocking but I have been wrong before
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
Trouble is, you may not be able to see the delamination.
But at high speed with the centrifugal force, it could be happening within the tyre.
This will cause the sound you described.
Anyway, it's up to you. I'm just suggesting a possibility to your problem.
Wont hurt to get them checked.
Better safe than sorry.
