2001 vu v6 problem
G.nuts
Australia
Vu
can anyone help..
2001 vu v6 auto
when cold is ok
As it worms up has a miss and bad under load in gear. In park it will revs out just fine.
just coasting is ok but i put my foot down its bad..
I have done
fuel pump
Fuel filter
Leads
Plugs
Coils
Coolent temperature sender
CAS
fuel pressure regulator today with no difference...
Injectors
I have had a code reader on it but no codes come up..
What to do next.
Please help me
immortality
Staff member
Sth Auck, NZ
Only one thread required!
Have you tried cleaning the MAF?
Checked fuel pressure? It could be a problem with the fuel pressure regulator.
May also be an O2 sensor problem.
G.nuts
Australia
Vu
Havent done o2 yet but everything else looks good and is new
I have orded a new CAS from super cheap and might do o2 when waiting for that.
G.nuts
Australia
Vu
Have swaped o2's from my vy had no difference. It starts up good but as it worms up its missing bad...
Just wait for the CAS i guess
G.nuts
Australia
Vu
Did you happen to take any notice of the dfi plug? Any carbon or crap on the pins?
What is the condition of the wiring like?
Wiring looks good , pins where bit like Dusty
G.nuts
Australia
Vu
Did you clean them?
When refitting, where they a good tight fit? (dfi plug).
Yes cleaned with contact cleaner and was a tight fit .
I have started taking of the harmonic balancer off today so just gotta wait for the CAS now
I will report back when that is done ;)
