2002 Vu ute lights not flashing on lock/unlock
Barbs2015
Dilligaf
VU SS Ute
Hey guys, ive got a 2002 vu ss ute and was just wondering if anyone knows whats causing it to not flash the blinkers when i lock/unlock the ute, there meant to double flash on lock and single flash on unlock i think?
Not sure if its aftermarket bcm, and ive changed the bcm fuse to no avail
Any help would be appreciated
lout
60
Langwarrin Victoria
if the indicators and hazard lights works i would suspect faulty bcm
if everything else works, i would not worry about it
you could disconnect battery and then remove and reseat bcm wiring plugs
Barbs2015
Dilligaf
VU SS Ute
Yeah man the indicators and hazards work, will give reseat' a try, wouldnt happen to know the location of the bcm in the vu? up under the steering wheel or?
lout
60
Langwarrin Victoria
yep, up under steering wheel, behind fusebox
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
Probably just the relay in the bcm. Pretty sure they are replaceable.
BadDad62
VU SS Gen3 UTE
I had the same issue in my VU until recently they started flashing again, go figure??
