2002 Vx Commodore Aclaim Climate Control Conversion
dylan720
vp cxommordore
Hey guys i have just done a climate control on 02 vx commodore aclaim. And for some reason the lcd panel wont light up when i turn on mu=y headlight and theres also a little x in the bottom right hand corner. Everything seems to work fine i was just wondering if anyone could help me out. Thanks
PeterRussi
VY Cab Chassis
The little X means there is no outside ambient temp sensor connected
lout
Langwarrin Victoria
VX Executive S2
if the little x is on your dash triple window display that means there is a communication fault between the modules
BlackVXGTS
Melbourne, SE
You need to get your ECC trouble codes displayed using a Tech2 or equivalent. The are a dozen ECC trouble codes that could cause the "x" to be displayed. Ambient Temperature Sensor Voltage High (DTC13) and Voltage Low (DTC14) being two of them. Did you get the HVAC from the same car that you obtained the ECC module? Did you check that the globes in the ECC module were working before you installed it in the car? Did you convert the globes to LEDs by any chance?
