jcvince
Hi,
I bought a pair of Auto-Force shock absorbers and two Mackay strut mounting kits (bearing and bearing assembly/bush).
After taking the old shocks off and disassembling, I noticed that the new bump stop and dust cover/boot (came with the new shock absorber) were both very different to the old ones. I ended up using the old dust cover/boot because I couldn't get it to work, and after some fiddling I got the new bump stop to fit. I assembled like the picture below shows.
I fitted the new shocks to the car, tightened the nut over the locating plate/washer, lowered the car and then tightened again. I had a lot of trouble with the 10mm hex head on the piston rods as they seem to be just over 10mm and even with a ring spanner were slipping.
After a test drive and a bit of bouncing the car by hand, I noticed that the locating plates/washers are moving up and down with the bounce of the car. I'm assuming this is not normal (even though it's only small).
Has anyone had trouble with the Auto-Force shocks before?
Where have I gone wrong or do you think once it "settles in" it will be ok?
Any feedback would be appreciated!
Thanks,
Jack
Thanks,
Jack
