corhijasna
- Sep 28, 2013
- 681
- 15
- 18
- Age
- 51
- Location
- Portland Victoria
- vz ss commodore / WM Caprice V
As the last 2 members have said,you can change the oil however this will only be a temporary measure,the lifters etc are buggered and you need to essentially do a top end rebuild or just change the lifters however as the heads are off may as well do the cam etc at the same time, the fans shouldn’t be coming on at start up so you may need to change the sender that’s located in the radiator ,I could be wrong ,hard to tell without actually seeing it in person
