2003 VY Berlina, First Car
luke641
ST33ZE: A Berlina Thing
Cronulla
2003 VY Berlina with Calais Bits
2003 VY Berlina with Leather Interior and Calais Bits, My First Car
Hi all, thought I would make a thred and post up some pictures on my first car, a 2003 VY Berlina.
Specs
Model: 2003 VY Berlina
Colour: Delft Blue
Engine Type: 3.8L Ecotec with 170xxxkm, High I know, But serviced regularly every 15000km.
Engine Mods: N/A
Gearbox: 4 Speed Auto
VY/VZ Calais 17' rims with 235/35/r17's
Tinted rear windows, not sure if front are. Unsure of tint strength.
Full leather interior, Factory Option
Lowerd. Unsure of amount or type of spring
Future Plans:
Pay off the money I borrowed for it
Chrome S2 Number plate surround
Exhaust
VY/VZ Calais Lights - Done
Calais Bumper reflectors - Done
Clean up/repaint rear/front bumpers - Done(no repaint)
Amp/Sub - Done
7' Touch screen DVD/CD/TV Player
+ Will add more as I think of it.
No bad for a first car... The paint is in good condition, has a larger amount of scratches then usual, but most will come out with a good cut and polish, wax etc...
Any comments/advise/input welcomed.
Pics
Luke
TMM
OEM+
VIC
VY Berlina S2
That would be Delft Blue :beer chug:
It's definitely lowered, the VZ Calais rims suit it well.
Berlina's usually have a few bumps and scrapes - mine did as it was a family car. :)
luke641
Cronulla
Yer it looks great IMO. I looked at a few other Berlina's, all similiar, or worse paint wise, none with leather interior.
The guy at the dealership said it was parked in a narrow, units garage, hence the bumps to the front and rear..
Thanks for the paint name.. Can you buy touch up for it? Any places in particular sell it?
Rusty
٩(-̮̮̃•̃)۶
Queensland
Vt with VU/VZ bits
Love the rims mate! your going to PM me if you ever sell them!! They always look good whitewalled too. May look pretty dam good on yours!
Maybe some chrome window surrounds will suit it if ur going with the chrome number plate surround. Great car mate!!
Edit: I'm a tool, looks like it comes with chrome window surround
luke641
Cronulla
Yer ill post up some interior pics when i pick up the car on Wednesday. Its Black leather. With the woodgrain gear leaver surround and coin tray.
White walls is a option. Might do a photoshop of it with them.
But before any major mods, needs a good cut and polish, wax, etc.
And yes it has chrome window surrounds.:D
EDIT:
Here is a pic of Jbird's Interior in his Berlina. Its the exact same as mine, minus the twin gauges above the center console. (His car is also the same colour.. lol)
Jbirds car:
http://forums.justcommodores.com.au/vy-vz-wk-wl-v2/85221-my-sacked-vy-berlina.html
luke641
Cronulla
Oops Double Post..
But since i have a post... I shall ask a question.
The cleaning up the paint will be the first real thing i do with it. The previous owners had a small narrow garage so there is a few concrete scrapes on the front and back bumpers. As well as a few other scratches. Most should come out with a Cut and Polish,Wax.. Etc...
For touching up the paint.. Can i buy GM touch up paint? Or could i use a product i saw:
http://www.turtlewax.com/main.taf?p=2,1,4,5
Any one tried the turtle wax product?
Also, is the a plate or somthing rather, that tells me exactly what the name of the paint is?
And also, if anyone can tell if its lowered(or by how much) that would be great! (springs look grey like the FE2's?)
TMM
OEM+
VIC
VY Berlina S2
Look in the engine bay, there's a build plate above the passenger headlight which has the paint code (a few numbers/letters) and will also tell you the suspension the car came with - "STD" for FE1, and "FE2" for FE2. The height looks like FE2 to me.
If you go to the parts counter at Holden they have small bottles of touchup paint in all the standard commodore colours.
The general rule of thumb for scratches/chips is, if you can catch your nail on it polish alone won't fix it. All the polishes that claim to work on certain colours are a bit of a gimmick as they just fill up the scratches with a colour filler which eventually wears off and the scratch reappears.
Using an abrasive polish you can improve the appearance of deep scratches by 'rounding off' the edges of the damage, but you'll never remove it completely unless you bring the rest of the paint down to the same thickness as the trough of the scratch, and that is impossible for scratches that are all the way through the clearcoat.
For scratches that polishing alone won't remove, but aren't all the way through the clear coat you can carefully wet sand them back with 2000grit+ sandpaper (don't sand through the clear!), then polish out the sanding marks.
For deeper scratches/scrapes (through to the color coat, primer or metal) the only way to fix it 95%+ without respraying the whole panel is this:
-clean the area thoroughly with wax and grease remover to remove any dirt or polish residue in the chip/scratch. A claybar is also a good idea if you have one.
-If you have a scratch through to bare metal, first remove any rust (a small engraving bit is handy) then apply some metal etching primer to the bare metal.
-carefully fill the scratch/chip with touchup paint, remembering you just want to fill the scratch not the good paint around it - i've seen people use a needle or syringe to put paint on a scratch rather then the sloppy brush that touchup bottles use.
-You may have to apply a few coats to fill it up just a little bit higher then the level of the good paint around it - remember wait for it to be touch dry before applying another coat, and lots of thin coats are the key here. You don't want to just put a massive blob on because it'll just make more work for you later.
-once it's filled, wait for the paint to harden - at least a week, preferably a month.
-carefully wet-sand it flat with a high grit sandpaper (2000grit). This is the risky part as you don't want to sand through the clearcoat on the good paint around the scratch, as that would require a respray of the panel to fix. You'll want to use a small sanding block otherwise you'll get a wavy reflection in the paint. I use a 1cmx1cm square of balsa wood as a mini sanding block with a 2cmx2cm piece of paper, sand for about 5 seconds, then spray it down with water and wipe it with a cloth to see how i'm progressing. When the sandpaper gets clogged up with touchup paint get a new piece of paper.
-If you've done it right, the damage should be invisible now, the paint will have a matte finish left by the sandpaper.
-Then you can polish out the matte finish left by sanding. I use Meguiars ScratchX 2.0 by hand, it takes 4-5 hits to remove all the sanding marks.
-The repair is virtually invisible, you may only notice it under bright lights or direct sunlight :).
Heres a guide for stone chips, the method is the same for scratches:
http://www.detailingworld.co.uk/forum/showthread.php?t=20127
pempa
VL SL
Very nice man, cant wait to see what it looks like when your done, i love a vy slammed on whitewalls they always look tough!
