2004 VZ alloytech engine cut out
hilly76
albany WA
2004 VZ ACCLAIM
heya ppl , ive got a 2004 vz acclaim 3.6 alloytech , problem im having is every now and then the engine cuts out when cornering . mostly when going right . have had it checked for codes but nothing has shown up :( :(
anyone else come across this problem ???????
stick3
newcastle nsw
vz sedan vs ute gsx1400
has the fuel pump been replaced and how much fuel in the tank does it do it when the tank is full
hilly76
albany WA
2004 VZ ACCLAIM
Doesn't matter on what level tank is . I'm starting to think wiring but where to bloody start
stick3
newcastle nsw
not fuel than and it happens when you turn could be a loose or broken wire in the steering column or ignition
hilly76
albany WA
2004 VZ ACCLAIM
im going to take it too a auto sparky . getting a new fuel pump next week . doesn't seem to have much get up and go
hilly76
albany WA
2004 VZ ACCLAIM
OK have an update . only does it when I turn the left indicator on with force . if I'm gentle when doing it its OK . may have a dicky switch or something to do with cruise control
