jd71
Hi guys,
Firstly, the number of times I've searched a problem with my car and found a link to this forum on google top result with help has been massive over the years !! So thanks to anyone that's helped people on here, google doing its job!!!
I have a vz sv6 auto, I will drive to my mums place (50km) and it'll be fine, I will drive back a couple hours later and I stop half way at milk bar and it's getting a bit warm. I know my temp gauge and it's sitting on about two and a fraction notches, about a half a notch or a notch higher then usual. And under the bonnet you can smell that coolant/overheating smell. I let it cool down, coolant level seems ok, drive home and then on the way home the temp gos down at least a notch, hardly any smell. Checked coolant reservoir on cold car and it looks like it's over the full hole mark on stick.
Yesterday I went into town, noticed the gauge up that little extra like before, can smell the coolant again, drove home ok, temp reduced again a little on drive home, checked coolant this morning and coolant reservoir still full or even slightly over full. Also, opened that coolant cap on the motor and seemed a bit dirty, could see a bit of coolant in there, I'm not sure if that's good or bad, in the past it's been clean in there.
Firstly, it does need an oil change asap, could this be a reason for slight overheating? I talked to a guy at Holden shop just where I actually had parked my car and he said it's unlikely to be a oil issue, something else.
Any advice? I am strapped for cash but the thought of losing a vehicle gives me a tumor!!!
Could i fix the problem by going and giving it a oil change today? I'm certainly no mechanic but I've read a guide on here about changing oil, I think I'm up for that challenge. (Oil change, oil filter change) Or should I attempt flushing the coolant? I should say the radiator was replaced a couple years ago after it had a hole in it, but had no issues up u til recently.
If you guys could give me any advice at all for some thing I might be able to do myself, or you think I should take it straight to a mechanic that would be great.
Thanks
Thanks
