Hi, thanks for the comment!! It's got red in it now, I live outside of city are and the servos here only have some crappy blue stuff so I'll have to drive to supercheap or autobarn, he probably didnt even bleed it, I read on here that a lot of mechanics dont think you need to. Is it beneficial to empty the old coolant from radiator or will I just top up with new red coolant,. and just need to know if I have to get nulan coolant or i can get a cheaper one they have, auto barn have a special still on so i may just get the nulan one. And I have to get distilled water? spring water no good from aldi?Just depends how much you want to spend.
Topping it up at the pressure cap like your mechanic said is a good place to start then bleed air with the screw. It should always be full up to the pressure cap. Still sounds like you need a new cap to me to stop it all ending up in the reservoir unless it's leaking somewhere else and you've been filling the reservoir rather than the pressure cap? ( you should try to get both at the right levels).
The red 50/50 mixed coolants are the easiest to use like the Nulon one, assuming your mechanic hasn't put green in it? They go on sale quite often.
THANKS MAN, should be ok for the commodore yeh? just bleed it with the screw on radiator and heater on?Well Nulon and most of the other brands have 2 types of red coolant. The concentrated one and the premixed one. If your just doing top ups it's easier to use the premix and just pour it in, you don't need to mix it with distilled water.
thanks for your help, thats perfect, see how it go's and I'll post back after Ive done some trips, see if it helps. I really need to change the oil, its old and gross, thats my next job.
