2006 Alloytec (LEO) V6 Cranks - No Start
Bethanga Auto
Bethanga, Victoria
VZ Commodore
No check engine light on - Connected scan tool no logged/active codes & scan tool indicating all ok. Checked fuel pressure 4.1/4.2 Bar - Okay. Swapped engine relay with another. No difference. Removed crankshaft sensor & check ohms 851 (Spec 851-1040). Fitted new sensor anyway & no joy. Sprayed aero start into intake system & engine not even trying to start (Indicating no spark). Any ideas further checks would be appreciated
_R_J_K_
Zenki S14
Does it do anything if you unlock the car beforehand?
Bethanga Auto
Bethanga, Victoria
VZ Commodore
Not sure what you mean - Car had to unlocked prior to trying to start several times & to attempt to diagnose problem up till now
99notout
VZ Equip Wagon
Test the coil circuit. Grounds, power and signal.
Trevor loves holden.
vs commodore
DFI maybe, immobiliser playing up, key fob, faulty engine computer or ecu, change plugs first then that fails get a second hand ecu and bcm with fob that match your numbers very common problem.
Big Red VF-SII Go-kart
I love puddles.
Darwin NT
VFII MY17 SV6 (LFX) Sportwagon (SOLD)
Clean the stainless steel rim around the ignition barrel where the key transponder's nib makes the handshake with the immobiliser. A worn nib (that round bob to the left of the key shaft), or dirt/grease or whatnot on the SS rim, can interfere. When it does, you will usually get an Immobiliser Fuel Disable Signal Received code (in scanner). and the car will be set to limp mode and be quite reluctant to pick up speed, providing even if it does start. A completely flat battery in the key transponder will not transmit anything to the immobiliser.
Don't touch any ECU, BCM, plugs, coils or any other component until you have had a good look at the key and it interaction with the immobiliser. A dead/no-start situation can sometimes mean the immobiliser is in lock-down. (it is not so easy to find out why this is so, and attempted forced entry will not cause a lock-down situation). In a few cases I have seen of no-start, the key often turns out to be the culprit in many cases because people think they last forever and a day — they don't, and when the battery in the transponder dies, it's going to cause problems, including difficulty in coding a new key (you should have a spare key/transponder as a fallback). Another test is to completely arm/disarm the immobiliser:
  • Shut all doors.
  • Press lock once, press lock again. The indicators will remain on for a few seconds.
  • Wait a few seconds.
  • Press unlock, press unlock again. Indicators flash normally for unlock situation.
  • Start the car.
This process is a variation of the normal lock, except it deadlocks the doors (e.g. the lock nibs cannot be forced up).
Check ignition relay in console on driver's side finder top.
