Don
- Oct 23, 2012
- 2
- 0
- 0
- Location
- melbourne
- 2006 Commodore VE SV6
G'Day Gents,
Recently my mechanic found out that water has been getting mixed up with transmission oil because of a leak in the radiator. This was found out when I took the car for an inspection, when it started revving up but not changing the gears smoothly. The mechanic suspected that the water leak was the problem but however didn’t fix the revving issue, the car was still revving without changing the gears and "Stability Control Off" error started popping up more often (it used to pop up even before but not as often as it was just then). When this stability control off error comes through, the gears won’t change at all now, car just revs up.
When the diagnostic computer was connected, the mechanic told something is wrong with the "peddle switch" and was 80% certain that the issue was due to this. After replacing this, still the issue want fixed, the car seems to drive alright until the "stability control off" error comes up on the dash.
Now the computer inside is getting dismantled and being sent off to some third party for checking. Hopefully this gives me some result, been spending so much money and I am kind of over it already.
Have you gents ever experienced such issue? Any advice will be much appreciated guys.
Don
Don
