2006 ve vin locked out
soleyacejnr
19
NSW
2006 ve
i have brought a 2006 ve with a broken key barrel so i swapped out the the key and key housing ecu and the bcm out of a ve that has been written off and the radio is coming up with [security lockout active vehicle data mismatch] with the dash saying [vehicle immobilized refer to owners manual] i have it booked in to be looked at by an auto elc but his not confident he can fix the problem dose anyone have any ideas on how to resolve the problem or come across this bf on a 06 model
Fu Manchu
Auto Correct is not my frog ballet.
Western Australia
Kia Sorrento, VZ Crewman, VZ Cross 8, & ya mum.
No no no.
You can’t do that.
There is so many modules on a VE.
You can’t swap just the ECM and BCM. It has to be all the modules. Everyone of them has to be VIN matched or a no start condition occurs.
It was VZ you could get a computer and key set for. VE is no where near that.
Put all you original stuff back in. Get a locksmith to come and set up a new key for you. The key has to have the transponder in the plastic.
A broken key blade just means you remove the key barrel and get it to a lock smith who can cut a key according to the pins in the barrel. Or you would change just the ignition key and the door with a new key blade that matches as well.
Fu Manchu
Western Australia
If you don’t wish to do those things, you will need a high end bi-directional scan tool and go through and perform the long and tedious task of matching up all the other 15 or what ever modules throughout the car with the VIN from the donor car that you got the ECM and BCM from. Then the car starts. It’s a shtshow of a job.
soleyacejnr
19
NSW
2006 ve
No no no.
You can’t do that.
i apologies i didn't realize i forgot to mention this in my original post
but i brought the car ( car A ) when it was already in this mode
as the owner before me had lost the key
he decided to pull apart the key housing ( snaped the metal keeping it on the wheel )
and when i brought the car it came with the broken key housing sitting in the back of the car
and 2 BCM and 2 ECM witch at the time i didn't even know what they where
so at the moment i have 3 BCM and 3 ECM with 1 key housing with no key and 1 key housing with a key
i have marked the key housing and the BCM and the ECM that came out of the written off ve ( car B )
is there a way to can tell witch combination of the other 4 are the originals ones for ( car A )
and if so is am i able to use the key housing and key off the ve that was written off ( car B ) with the right BCM and ECM from ( car A )
or is there a list of all the modules ill need to swap from ( car B ) or what bi-directional scan tool will i need to buy to help find them
soleyacejnr
19
NSW
2006 ve
also sorry it was such a late reply i have just gotten home from work and didn't have time yesterday ( Thursday ) to reply
DavesSV6Tonner
Luggage Point, Brisbane
VZ S V6 Cab & Chassis
Might be better off taking the car to someone with a Tech 2 and paying them to find which BCM and ECM match your car's VIN.
I'm not real tech savvy when it comes to electronics in cars but surely the ignition switch & key assy can be replaced without having to replace the ECM & BCM?
Fu Manchu
Western Australia
What you need to do is install the original ECM and BCM
You need the original key fob. It has an important transponder embedded in the plastic. That communicates to the key reader under the steering wheel.
Buy a new/replacement ignition barrel. A new replacement door lock barrel.
Or take the ignition barrel (original) to a locksmith who specialises in car keys. They will disassemble the barrel, get the key profile and cut a new key blade.
Problem sorted.
Getting a bi-directional scan tool that can reflash the multitude of modules throughout the cars computer network will be around $1000 once all the components are bought. Tech2 is the device used by Holden. There are others that can do it but they will likely have higher price tags.
Using the scan tool to perform module VIN matching takes a bit of skill and knowledge. Get it wrong and you could brick the car.
Fu Manchu
Western Australia
There are plenty of YouTube vids on disassembling a G8 or VE key.
Just don’t discard the original key fob with the transponder embedded in the plastic. That is a different thing to the removable circuit board inside.
soleyacejnr
19
NSW
2006 ve
i don't have the original key fob as the owner bf me lost it and that's where the hole trouble started is there another way to get around not haveing the original key fob if i can figure out witch bcm and ecm is the original
soleyacejnr
19
NSW
2006 ve
ill look into this option thank you
