VZ 3.6L Engine: codes refer to generic code lists at front of manual. P1011 Intake Camshaft Actuator Park Position (Bank 1) P1012 Exhaust Camshaft Actuator Park Position (Bank 1) P1013 Intake Camshaft Actuator Park Position (Bank 2) P1014 Exhaust Camshaft Actuator Park Position (Bank 2) P1258 Engine Coolant Over Temperature – Protection Mode Active P1551 Throttle Control Lower Position Not Reached During Learning Mode P1629 Immobiliser Fuel Enable Signal Not Received P1632 Immobiliser Fuel Disable Signal Received P1648 Wrong Security Code Entered P1668 Alternator L Terminal Circuit Fault P1677 Immobiliser Function Not Enabled P1678 Engine Control Module Identification Failed P1679 Immobiliser Environment Identification Failed P1845 Engine Torque Reduction Fault P2008 Intake Manifold Runner Control Solenoid Circuit Fault P2009 Intake Manifold Runner Control Solenoid Circuit Low Voltage P2010 Intake Manifold Runner Control Solenoid Circuit High Voltage P2088 Intake Camshaft Position Control Solenoid Circuit Low Voltage (Bank 1) P2089 Intake Camshaft Position Control Solenoid Circuit High Voltage (Bank 1) P2090 Exhaust Camshaft Position Control Solenoid Circuit Low Voltage (Bank 1) P2091 Exhaust Camshaft Position Control Solenoid Circuit High Voltage (Bank 1) P2029 Intake Camshaft Position Control Solenoid Circuit Low Voltage (Bank 2) P2093 Intake Camshaft Position Control Solenoid Circuit High Voltage (Bank 2) P2094 Exhaust Camshaft Position Control Solenoid Low Voltage (Bank 2) P2095 Exhaust Camshaft Position Control Solenoid Circuit High Voltage (Bank 2) P2096 Post Catalyst O2 Sensor Fuel Trim Below Lower Limit (Bank 1) P2097 Post Catalyst O2 Sensor Fuel Trim Above Upper Limit (Bank 1) P2098 Post Catalyst O2 Sensor Fuel Trim Below Lower Limit (Bank 2) P2099 Post Catalyst O2 Sensor Fuel Trim Above Upper Limit (Bank 2)
P2100 Throttle Control Motor Fault P2101 Throttle Control Position Range/Performance P2105 Throttle Control Forced Engine Shutdown P2107 Throttle Control Fault P2119 Closed Throttle Position Range/Performance P2122 Accelerator Pedal Position Sensor 1 Voltage Low P2123 Accelerator Pedal Position Sensor 1 Voltage High P2127 Accelerator Pedal Position Sensor 2 Voltage Low P2128 Accelerator Pedal Position Sensor 2 Voltage High P2138 Accelerator Pedal Position Sensor 1-2 Correlation P2176 Throttle Control Lower Position Not Learned P2177 Fuel Trim Lean During Cruising/Acceleration (Bank 1) P2178 Fuel Trim Rich During Cruising/Acceleration (Bank 1) P2179 Fuel Trim Lean During Cruising/Acceleration (Bank 2) P2180 Fuel Trim Rich During Cruising/Acceleration (Bank 2) P2187 Fuel Trim Lean During Idling/Deceleration (Bank 1) P2188 Fuel Trim Rich During Idling/Deceleration (Bank 1) P2189 Fuel Trim Lean During Idling/Deceleration (Bank 2) P2190 Fuel Trim Rich During Idling/Deceleration (Bank 2) P2195 B1S1 O2 Sensor – System Too Lean (Bank 1 Sensor 1) P2196 B1S1 O2 Sensor – System Too Rich (Bank 1 Sensor 1) P2197 B1S1 O2 Sensor – System Too Lean (Bank 2 Sensor 1) P2198 B1S1 O2 Sensor – System Too Rich (Bank 2 Sensor 1) P2227 Barometric Pressure Sensor Range/Performance P2228 Barometric Pressure Sensor Voltage Low P2229 Barometric Pressure Sensor Voltage High P2231 O2 Sensor Signal Short To Heater Circuit (Bank 1, Sensor 1) P2232 O2 Sensor Signal Short To Heater Circuit (Bank 1, Sensor 2) P2234 O2 Sensor Signal Short To Heater Circuit (Bank 2, Sensor 1) P2235 O2 Sensor Signal Short To Heater Circuit (Bank 2, Sensor 2) P2237 O2 Sensor Pump Current Circuit Fault (Bank 1, Sensor 1) P2238 O2 Sensor Pump Current Circuit Low Voltage (Bank 1, Sensor 1) P2239 O2 Sensor Pump Current Circuit Circuit High Voltage (Bank 1, Sensor 1) P2240 O2 Sensor Pump Current Circuit Fault (Bank 2, Sensor 1) P2241 O2 Sensor Pump Current Circuit Low Voltage (Bank 2, Sensor 1) P2242 O2 Sensor Pump Current Circuit High Voltage (Bank 2, Sensor 1)
Holden Diagnostic Trouble Codes
Holden VZ continued:
P2243 O2 Sensor Voltage Signal Circuit Fault (Bank 1, Sensor 1) P2247 O2 Sensor Voltage Signal Circuit Fault (Bank 2, Sensor 1) P2251 O2 Sensor Ground Circuit Fault (Bank 1, Sensor 1) P2254 O2 Sensor Ground Circuit Fault (Bank 2, Sensor 1) P2270 O2 Sensor Lean/Rich Switch Signal Fault (Bank 1, Sensor 2) P2271 O2 Sensor Rich/Lean Switch Signal Fault (Bank 1, Sensor 2) P2272 O2 Sensor Lean/Rich Switch Signal Fault (Bank 2, Sensor 2) P2273 O2 Sensor Rich/Lean Switch Signal Fault (Bank 2, Sensor 2) P2297 O2 Sensor Range/Performance During Deceleration Fuel Cutoff (Bank 1, Sensor 1) P2298 O2 Sensor Range/Performance During Deceleration Fuel Cutoff (Bank 2, Sensor 1) P2300 Ignition Coil Cylinder 1 Circuit Low Voltage P2301 Ignition Coil Cylinder 1 Circuit High Voltage P2303 Ignition Coil Cylinder 2 Circuit Low Voltage P2304 Ignition Coil Cylinder 2 Circuit High Voltage P2306 Ignition Coil Cylinder 3 Circuit Low Voltage P2307 Ignition Coil Cylinder 3 Circuit High Voltage P2309 Ignition Coil Cylinder 4 Circuit Low Voltage P2310 Ignition Coil Cylinder 4 Circuit High Voltage P2312 Ignition Coil Cylinder 5 Circuit Low Voltage P2313 Ignition Coil Cylinder 5 Circuit High Voltage P2315 Ignition Coil Cylinder 6 Circuit Low Voltage P2316 Ignition Coil Cylinder 6 Circuit High Voltage P2500 Alternator L Terminal Low Voltage P2501 Alternator L Terminal High Voltage P2626 O2 Sensor Pump Current Trim Circuit Fault (Bank 1, Sensor 1) P2627 O2 Sensor Pump Current Trim Circuit Low Voltage (Bank 1, Sensor 1) P2628 O2 Sensor Pump Current Trim Circuit High Voltage (Bank 1, Sensor 1) P2629 O2 Sensor Pump Current Trim Circuit Fault (Bank 2, Sensor 1) P2630 O2 Sensor Pump Current Trim Circuit Low Voltage (Bank 2, Sensor 1) P2631 O2 Sensor Pump Current Trim Circuit High Voltage (Bank 2, Sensor 1)
U0001 No Communication With CAN-Bus (High Speed) U0101 CAN-Bus No Communication With TCM (Transmission Control Module) U0121 CAN-Bus No Communication With ABS/TC/ESP U0155 CAN-Bus No Communication With Gateway U0415 CAN-Bus Invalid Data ABS/TC/ESP U0423 CAN-Bus Invalid Data From Gateway
