2007 ve sv6
Pinkfrangipani
Central coast
Ve sv6 2007
Hi does any one know why I would have petrol in my motor at all I did the chains new oil pump new spark plugs it cranks but won't start pulled the spark plugs out they stink of fuel any help will be greatful
hookalaya
VE Calais 3.6
Maybe the base timing is out or there's an ignition problem where the fuel ain't been burned up in the combustion process so it stays wet on the plugs
Fu Manchu
WA.
What’s the go on flood mode? Foot flat to the floor?
mr_s
VE Lumina 07
VE's have the electronic throttle and they've also installed a limiter on revs (at least in idle) to max out at 4000 RPM.
IF OP flooded it in neutral/park, I just dont think it would be possible to do that with e-carbs.
Likely the chains are out of alignment/skipped a tooth.
OP, do you have a OBD tool?
Fu Manchu
WA.
I’m well aware of the electronic throttle. There is a process to go through without the Tech2 that can help. It’s outlined in the factory manual.
I just don’t recall what that process was.
PaulMcGTS
Donating Member
58
Narre Warren
Holden Special Vehicles GTS 2007 VE Sedan 6.0 i V
Chains as in timing chains? If fitted incorrectly, you have a few bent valves. Was there any initial clunks when you first turned it over. A compression test may tell you something but my guess is valve related.
Martbar
67
New Zealand S.I. Otago.
2016 VF Series 2 SSV Redline.
Hey Paul, they haven't logged on for about a year. It wasn't a bad thread, but it looks like we're unlikely to know the outcome.
