RiCeY
F O R U M W A R R I O R
- Mar 29, 2005
- 4,126
- 492
- 83
- Location
- Australia
- VZ SV8 6spd 6.0 430rwhp
You have the wrong cap fitted there haha
Very common issue the spout snapping off.
To disconnect the Auto trans lines follow the pipes from the radiator to about level with the front of the engine, you will see two circular plastic rings at the two connections. Push the rings back and you will expose a metal clip that you pry out with a very small screwdriver or pick. The pipe will then pull out. Once the radiator is out remove the pipes at the radiator with the same clips.
