VFSV6FORME
- Mar 9, 2016
- 2,603
- 1,273
- 113
- Age
- 74
- Location
- Brisbane
- WN Caprice V 6.0L, VE Anniversity V6 Series 1
FOUND and removed the window Control module
If i check the Power Windows RAP with the fuse out only the top has 12V. No 12V on the other side
easy to get the window control module apartm LOOK under Mad Light NO High resistance joint anywhere. Where is the rap relay? Argh i know. Why do you think I have no power on both sides of that fuse breaker? Or the RAP relay which is hidden behind a massive loom and hard to get at. Is this the one you are talking about? If so, have no power on both sides, what could cause this?if the rap relay is not energising you will not get power to the window control module
No power on both sides of fuse 24 2A RAP Control PWR WDOsorry.
are you saying you have power on the fuse 24, 2a power window control fuse
