VFSV6FORME
- Mar 9, 2016
- 2,603
- 1,273
- 113
- Age
- 74
- Location
- Brisbane
- WN Caprice V 6.0L, VE Anniversity V6 Series 1
I will fit by cable ties the control module up where it live as it just about impossible to get it in the correct position and will have a go on theRelay R1, Rap 1 whatever he calls himself
pin 30 battery volts
pin 87 normally open
pin 85 is output from bcm, battery volts when engine running
pin 86 is ground
pin 87 receives power if relay closes. it then supplies that power to the circuit breaker B1, circuit breaker B2 and fuse 24
relay tomorrow, thankjs for your help, need a rest
pin 86 is ground
