2009 Holden VE Commodore Calais
279Henry
61
Eastern Creek NSW
2009 VE Commodore Calais
I'm need help. has anyone come across this error code P2177-00 Fuel Trim Lean during Cruising/Acceleration(Bank 1) and how did you fix problem, I do realised it could be be more than one problem thanks in advance for your help.
Martbar
67
New Zealand S.I. Otago.
2016 VF Series 2 SSV Redline.
Mate according to google and in no particular order
Fuel injectors, clean or replace
Fuel pressure reg.
Mass air flow sensor
O2 sensors
Air intake leaks.
Check the easy stuff first.Did you look at similar threads at the bottom of the page? Someone else will probably chime in. Good luck.
krusing
Melbourne, Bayside
V6 or V8 ?
@Martbar As above ^^^^ is the best starting place,
(if its a V6) it could even be chains,
Cam plates, (Lets not go there at the moment)
Cam actuators,
