2009 Maloo won’t crank
Donrogers
33
Mackay
2009 maloo
I bought a 2009 maloo that won’t crank. Dash fires up but head unit ect doesn’t. I’ve checked fuses everything seems fine there unless I’m missing something external from the fuse box. I can get it to crank if I jump the starter rely but no start as no fuel pump and spark. I’m thinking emobiliser problem?
I bought a cheap scan gauge to pull a fault code out but that won’t even connect.
Thanks
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
Check your fusible links.
Donrogers
33
Mackay
2009 maloo
Hey mate I’ve checked the on that is near the jumper post under bonnet on passenger side it’s got power either side. Is there another? There is power at the fuse box.
lmoengnr
Donating Member
Sunbury Vic.
They're in a small plastic box which is part of the battery cable, where it attaches to the battery terminal(behind the passenger seat).
BlackVXGTS
Melbourne, SE
Something like this:
